Yes you are correct , what sensors are you using?
I like to make my sensors in sets so the data will be coming from only one location
as this set WBGT sensors will be in mounted a 120cm mostly in full sun
Info of my other sensor sets
My weather station is made up from 1 wire modules
I have a 1 wire wet & dry bulb temperature sensor.
Which are mounted in a small Stevenson screen box
With a small fan drawing air across the wet bulb
Box is mounted at 120cm in shade most of the day
In the same box is a set of glass Thermometers Sheathed ordinary wet & dry Met Office pattern (BS692). So I check the 1 wire against the Sheathed wet & dry sensors
1 Wire Wet and Dry Bulb Sensor Untitled
I use a Solar radiation aspirated shield ,with a
HIH-4031 Honeywell Humidity Sensor and a DS18S20 digital thermometer.As main station air temperature & humidity mounted at 144cm in shade most of the day aspirated solar radiation screen
temperature humidity solar module
The new sensor is a DS18S20 mounted in a 6 inch copper ball panted black. This will be mounted in full sun . next to it will be a wet bulb temperature sensor using a DS18S20 mounted in a tube with a wet Cotton Wick in full sun . next to this will be the air temperature with a white shield on top mounted at 120cm this set of sensors
Will be used to work out the WBGT Index
Mick
