crash pc and hd wd reconstruction [solved]
Hi everyone and body,
A complete computer crash hard and software has obliged me to reconstruct a new PC.
Not to badly orginized I saved part of data on an separate (D:) hd. After fidling around, I managed to recover
all of the WD folder that was on the old C drive. (system drive)
Now on the new PC, HD I have installed latest version of WD.
Question: (answers partly only found on this forum)
In the new WD folder on the C: drive, what are the files that I can, should, have to recopy from recoverd data. ?
What are the file I should NOT restore. ?
What are ALL the file necessary to restore exactly same previous configuration and settings.?
Thanks for any as complete as possible help.
Kind regards.
-= Guy =-
PS: As one may see, my signature is down. :frowning:
there is a FAQ here on the forum for transfering WD to a new pc
that should cover alot of what is needed :wink:
Thanks for your answer. As usual before asking for anything I go thru this forum support.
I did find that topic at: http://discourse.weather-watch.com/t/10888
Problem, it was posted
what part of the FAQ is not working?
did you also copy across the datafiles and logfiles folders?
Yes I did…
Still not knowing how to correct
  • Day of last rain. ANSWER NOT FOUND
  • Days of rain in 2017. ANSWER NOT FOUD
Thanks for the help.
-= Guy =-
re the day of last rain
is that a custom tag you are using?
(what is that tag?)
(and same for the next question)
the more info you can provide, the better
$dateoflastrain = “%dateoflastrain%”;
$dayswithrainyear = “%dayswithrainyear%”; // Days with rain for the year
May be custom tags that I do not recall how to recover… :frowning:
Thanks regards.
-= Guy =-
for 1
you can set that in the wdisplay.ini settings file (when WD is not running)
[date of last rain]
value=
but if you are using a back up ini file, that should be being picked up
for 2, that uses the data files
make sure you have all the data files for this year
For 1: your suggestion solved it. Thanks.
For 2: As said, the reconstruction resulted from a complete computer crash. Some data file for 2017 where definively lost. I succeeded reconstrcting by importing .csv files from VWS that is running on an other PC.
I stilll have a question: Is it possible to convert the xxxxxlg.txt files to xx.inf files.? These had been rescued and it would have been an easier way to reconstruct!!
-= Guy =-
yes
via
action, convert WD logfiles to data files
also wunderground data can be imported too
Thanks Brian.
My case is definitely solved.
Others to come??? We will see… :wink:
