Author Topic: raindetail.gif and m2esomap.gif not updating  (Read 386 times)
Offline hcorrin
  • Ballaugh Isle of Man GB
  • Win NT 10.0
  • Mozilla compatible
    • Ballaugh Weather
« on: June 14, 2017, 10:23:18 PM »
raindetail
I updated my xmas/backup unit to 10.37S 49 then build 53 (original version) and neither version is creating the raindetail.gif at the times against #37 in file creation and upload the other files solardetail etc against #37 are created ok (this unit creates videos)
the programerrorlog shows this
ERROR: '' is not a valid integer value  System.SysUtils at time/date 20:10:12:584 14/06/2017
Above error or program log occured at :20 10 12 14/06/2017
error with file #37 '' is not a valid integer value
ERROR: '' is not a valid integer value  System.SysUtils at time/date 22:55:27:482 14/06/2017
Above error or program log occured at :22 55 27 14/06/2017
these times are when the raindetail file should be updated/created I have upload time set to 1 minute later.
the test unit that is configured as per main unit and does not create videos is creating the raindetail.gif ok and no error in log
m2esomap
the m2esomap.gif file is not updated/created on either unit with 10.37S 49 or 53 on and the programerrorlog is giving
weather map error 151: HTTP protocol error. 404 Not Found.
Above error or program log occured at :20 21 14 14/06/2017
Above error or program log occured at :20 51 14 14/06/2017
Above error or program log occured at :21 21 14 14/06/2017
Above error or program log occured at :21 51 13 14/06/2017
Above error or program log occured at :22 21 12 14/06/2017
Above error or program log occured at :22 51 12 14/06/2017
these are the times that the m2esomap should be updated/created the mesomap.gif is updating ok at these times, a m2esomap1/7 is created however
not sure what is wrong
Harold
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 58.0.3029.110
    • Weather Display
Re: raindetail.gif and m2esomap.gif not updating
« Reply #1 on: June 15, 2017, 12:02:32 AM »
I will need a copy of those
for the meso map, the problem is likely that the url for getting data, e.g wunderground, needs to change (now https and not http), or similar
Offline hcorrin
  • Win NT 10.0
    • Ballaugh Weather
« Reply #2 on: June 15, 2017, 07:26:32 PM »
Hi Brian
have sent the files to your email, let me know if you get them ok or not
Harold
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #3 on: June 16, 2017, 08:45:48 PM »
I have replied to your email
Offline hcorrin
  • Win NT 10.0
    • Ballaugh Weather
« Reply #4 on: June 16, 2017, 11:09:12 PM »
Hi Brian
I put the updated zip on and the raindetail.gif is created but there is a bit missing of the bottom, when I look in WD rain chart the bottom is missing off that as well.
the failed station in m2esomap was a typo on my part which has been there a long time wondered why it never had any data have put it right.
what I have noticed is that a file called mesomap2.gif is created when the m2esomap.gif should be created and this mesomap2 file has the up to date info and map in that should be in m2esomap.gif this has happen the past 3 times I have checked after the update was due. In 10.37r18 mesomap2 has map relating to the mesomap.gif. its as if the 2 is in the wrong place hope this is help.
Harold
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #5 on: June 16, 2017, 11:30:06 PM »
I do not have the missing data here
http://www.weather-display.com/windy/gb/raindetail.gif
so must be something about your settings
try deleting the setting
[Rain detail display colour]
last height=
from the registry
re your mesomap 2 issue, I am sorry, but I can not follow what you have posted
« Last Edit: June 16, 2017, 11:32:17 PM by Weather Display »
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #6 on: June 17, 2017, 12:01:46 AM »
I have made it so you can resize the rain detail screen now in the latest .zip update
Offline hcorrin
  • Win NT 10.0
    • Ballaugh Weather
« Reply #7 on: June 17, 2017, 05:58:30 PM »
Hi Brian
have put the latest update on and adjusted the rain chart size then did a create now and the result was ok will check the auto later this evening.
attached is my mesomap2.gif which was updated at 18:21 also the section of the webfile folder at that time, this image should be the m2esomap.gif
sorry if I am not explaining this very well
Harold
