Author Topic: Interface Weather Display with Nanhua anemometer  (Read 1817 times)
Online Weather Display
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 60.0.3112.90
    • Weather Display
Re: Interface Weather Display with Nanhua anemometer
« Reply #15 on: August 19, 2017, 12:05:57 AM »
use this update
(unzip to where you have WD installed) (exit WD first)
Offline icemannapoli
  • Naples - Italy
  • Win 7/Srvr 2008R2
  • Chrome 60.0.3112.113
    • http://www.campanialive.it/dati-meteo.asp?stazione=napolivomero
« Reply #16 on: September 18, 2017, 05:17:49 PM »
Hi Brian
i try to install this update but when i launch WD program the data not load and in the main window no wind data received.
Can i try to install WD into the same Nanhua anemometer directory ?
Cheers
  • Naples - Italy
  • Win 7/Srvr 2008R2
« Reply #17 on: September 18, 2017, 06:41:32 PM »
as the nanhua log records data is every minute,  for greater accuracy,  it would be best to read the WD directly to the serial port.
Can i set for you a sniffer serial port  software to remote control by you for a best setup ?
Have you suggestion for free sniffer serial port program?
Cheers
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #18 on: September 18, 2017, 08:08:35 PM »
Quote
yes you can
but you would need to use the latest full install update
why has it taken a whole month for you to back to me though?
the problem with direct serial has already been discussed
you would need to convert to RS232
