Author Topic: Weather Display and Meteotemplate API Rain Rate issue  (Read 1220 times)
Offline justinhow
  • Bit of a geek really
  • Slough, UK
  • Win NT 10.0
  • Firefox 53.0
    • East Berkshire Weather
« on: May 29, 2017, 08:19:27 AM »
I use Weather Display to pickup data from the Davis Vantage Pro2 and use the meteotemplate API to send to meteotemplate.
This is working fine an all respects except the rain rate.
This is shown OK on the WD control panel but Meteotemplate see a RR number that is far too low.
It was reading approx 3mm/hour in WD but this mapped to 0.1 or 0.2mm/hour in meteotemplate. The actual rain amount was also correct.
This could be a setup issue on my part but I have also asked Jachym and he wants to check that RR from WD is being sent in mm/hour via the API.
I am using WD 10.37S Build 44 with latest build of meteotemplate
Any help would be greatly appreciated.
Justin
« Last Edit: May 29, 2017, 08:27:35 AM by justinhow »
Station: Davis Vantage Pro2, Weather Display 10.37S53, Meteotemplate 14
http://www.eastberks-weather.com
Online Weather Display
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 58.0.3029.110
    • Weather Display
Re: Weather Display and Meteotemplate API Rain Rate issue
« Reply #1 on: May 29, 2017, 10:05:21 PM »
I would first be using the latest version of WD as I might have already fixed this (as I am not seeing other reports of this issue, as the latest version does use per hour)
« Last Edit: May 29, 2017, 10:09:41 PM by Weather Display »
  • Davis VP2
  • New Zealand
  • Android 5.0.1
  • Chrome 58.0.3029.83
    • Weather Display
« Reply #2 on: May 29, 2017, 11:14:07 PM »
Also just to note,it's an average,that is sent,as that
Is what I expected the api needs
Offline Jachym
  • Meteotemplate Developer
  • Brno, Czech Republic
    • jachym.czech
  • (Linux Mint)
  • Chrome 48.0.2564.116
    • Meteotemplate
« Reply #3 on: May 30, 2017, 12:10:28 AM »
yes, it should be the average over the API sending interval.
However Justin's values are way too low, I think he might be using old version of WD, I remember this was a problem at the beginning, which is now fixed.
Offline justinhow
  • Slough, UK
  • Win NT 10.0
  • Firefox 53.0
« Reply #4 on: May 30, 2017, 07:33:01 AM »
I have now updated to the latest WD version (build 49). The reason I didn't upgrade was because I didn't see anything on the changelog that appeared relevant.
Now I will wait for the rain which looks like it may be some time away :-(
« Last Edit: May 30, 2017, 10:13:06 AM by justinhow »
Offline Jachym
    • jachym.czech
  • Win 7/Srvr 2008R2
    • Meteotemplate
« Reply #5 on: May 30, 2017, 09:53:54 AM »
Quote
hehe... when I lived in the U.K. I usually never had to wait more than a few hours :D :D :D
Offline justinhow
  • Slough, UK
  • Win NT 10.0
  • Chrome 52.0.2743.116
« Reply #6 on: May 30, 2017, 10:15:40 AM »
There is an analogy with buses and police here.
There is never any when you want it and when you don't it is relentless   :x
Offline justinhow
  • Slough, UK
  • Win NT 10.0
  • Firefox 53.0
« Reply #7 on: June 06, 2017, 08:53:57 AM »
OK - there is still something wrong with this.
The Rain Rate as shown on WD control Panel (both the mm/minute and mm/hour) has very little correlation to the API RR info being sent to meteotemplate which is normally zero. On occasions it sends a one off high reading (probably correct) but then returns to zero on the next reading. The daily rain reading is perfect.
I am using the meteotemplate apiViewer to check values that WD sends
« Last Edit: June 06, 2017, 08:55:47 AM by justinhow »
Offline Jachym
    • jachym.czech
  • Win 7/Srvr 2008R2
    • Meteotemplate
« Reply #8 on: June 06, 2017, 09:24:06 AM »
OK lets see what Brian says, the numbers you see in API viewer come directly from the raw data file saved from the API bypassing the db etc.
Offline justinhow
  • Slough, UK
  • Win NT 10.0
« Reply #9 on: June 06, 2017, 09:27:55 AM »
It is quite possible that I have not setup something correctly in WD for my Davis Vantage Pro2 as I am very new to WD, however the WD app display does appear to show the correct values as far as I can tell.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #10 on: June 06, 2017, 06:24:55 PM »
what freq of data sending to MT?
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #11 on: June 06, 2017, 06:42:42 PM »
I will see if I can figure it out and let you know
Offline justinhow
  • Slough, UK
  • Win NT 10.0
  • Firefox 53.0
« Reply #12 on: June 06, 2017, 07:44:10 PM »
The frequency of the data as set in WD is every 5 seconds.
Justin
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #13 on: June 07, 2017, 05:42:07 AM »
try this update
which now provides the rain rate as a rolling 1 minute average
Offline justinhow
  • Slough, UK
  • Win NT 10.0
  • Firefox 53.0
« Reply #14 on: June 07, 2017, 07:34:06 AM »
Hi Brian
I have installed that and will feedback on the next downpoor! This may be Thursday/Friday looking at the forecasts.
Thanks again.
Justin
« Last Edit: June 07, 2017, 07:36:19 AM by justinhow »
