Author Topic: Really basic bugs that I cannot solve  (Read 999 times)
Online Weather Display
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 58.0.3029.110
    • Weather Display
Re: Really basic bugs that I cannot solve
« Reply #15 on: June 13, 2017, 12:32:31 AM »
try
exit WD
run regedit.exe
then search for
wdisplayftp.ini
in the registry
then find
[Summary image]
and
[Summary image background]
and delete those entries
Offline BWX
  • Win NT 10.0
« Reply #16 on: June 13, 2017, 05:14:02 AM »
Not quite sure on which part he does not get so i will try
Go to (top of WD screen) Setup, in that menu choose Advanced/Misc Settings
In there, chooses the Main Window Customise (if its not already on that tab)
Then click the top left box, its named Enable Move/Resize of the Objects
Click the Save Changes box (middle top) than click OK to come out out there
open the summary image by clicking on the large weather related icon on your WD main screen above the WD clock
If you have the Summary image in front of you then proceed, if not, re-read the above line ;)
Now you can resize it, move items around if needed, such as the min (in blue) and Max (in red) ;)
Code: [Select]
As a side note: you can save at any time by right click on the wind direction graph and in that menu
that pops up, scroll (if needed) right to the bottom and choose  Save changes to customisation of main screen
Firstly, just make it bigger like you would any over window,  then save like  mentioned above. Ok thats that done
You can now make the min and max a bit larger, well, if that part is on yours??? if not, you are done, if they
are visible and need enlarging then do this
If you hover your mouse over any item (most items in WD including some menu items too) and hold down the
CTRL button and then move the mouse (no need to click the mouse, CTRL is doing the click part) you will enlarge that item
i dont mean the font size, i mean the item itself, have a go, you will see.
If you hold down shift and move the mouse (again, no left or right click needed) that moves an item.
Hope that helps, if not, point out which part does not help?
