Author Topic: Real time client *Fixed*  (Read 3059 times)
Offline ALITTLEweird1
  • Mark
  • North Bend, WA
  • Win 7/Srvr 2008R2
  • Mozilla compatible
    • North Bend Weather
Re: Real time client
« Reply #30 on: August 18, 2017, 03:01:35 AM »
Pm Sent.
"Nature can do without man, but man cannot do without nature."
Davis VP2 + VP2 Solar + VP2 UV + Lightning Detector + Logitech Webcam
  • Davis VP2
  • Chrome 60.0.3112.90
    • Weather Display
« Reply #31 on: August 18, 2017, 10:46:36 PM »
I have tested here and it works with the ftp settings you sent me
but make sure to set the ftp port to 22 in the connections setup and tick use SFTP (ssh)
  • Mark
  • North Bend, WA
  • Android 7.0
  • Chrome 51.0.2704.106
« Reply #32 on: August 18, 2017, 11:35:25 PM »
 those are my settings.  However your testing this,  can you just let it run? This issue seems too happen at random times. I have not had the issue yet today either,  but it can happen at anytime.  I would just like you too see what happens.  Thanks
  • Davis VP2
    • Weather Display
« Reply #33 on: August 18, 2017, 11:57:38 PM »
its very hard to debug something that only happens randomly
when the problem occurs
the program should time out
and then retry, yes?
or?
i just tried running the real time ftp 10 times in a row (closing it each time) and it logged in OK each time and uploaded the files OK each time
  • Mark
  • North Bend, WA
  • Win 7/Srvr 2008R2
« Reply #34 on: August 19, 2017, 12:07:44 AM »
When the problem happens in the realtime, I need to crtr,alt, dl to shutdown the realtime and then open it again, then it works fine.
Hitting retry, stop or start does not work when this issue happens.
I know its completely random, but that's what is happening. I wish I could give you some more info, but that's what happens.
Liker I said too, it has not happened today yet, but it can at anytime. It normally happens at least once a day, sometimes twice. When it happens, is there anything you would like me to do or check before I restart it?
  • Davis VP2
    • Weather Display
« Reply #35 on: August 19, 2017, 12:14:23 AM »
it sounds like it gets locked in a loop or similar
so it does not recover?
and when it happens its in the log in phase?
and when it happens, is the program responsive at all to any clicks on the buttons or similar?
i.e the more information you can provide the better
  • Mark
  • North Bend, WA
  • Win 7/Srvr 2008R2
« Reply #36 on: August 19, 2017, 12:28:01 AM »
It does not recover. I need to shut it down and then restart it.
This is what it shows when it happens..
Quote
Logging off from server 3:50:37 AM
Logging off from server 4:21:02 AM
Logging off from server 4:51:27 AM
Logging off from server 5:21:52 AM
Logging off from server 5:52:18 AM
Logging off from server 6:22:43 AM
Logging off from server 6:53:08 AM
Logging off from server 7:23:33 AM
So here, it stopped at 3:50am and I restarted it at 7:23am
It is not responsive at all. I have to "control,alt, delete" to shut it down.
If I can think of anymore info to give you, I'll let you know. But as of now, this is all I have.
I know this is like chasing an electrical issue in a car, its no fun.
« Last Edit: August 19, 2017, 12:29:52 AM by ALITTLEweird1 »
  • Davis VP2
    • Weather Display
« Reply #37 on: August 19, 2017, 01:16:41 AM »
where exactly are you seeing that?
(and is it complete like that?)
in the actual program
or in the logfile?
its not very clear
  • Mark
  • North Bend, WA
  • Win 7/Srvr 2008R2
« Reply #38 on: August 19, 2017, 01:43:55 AM »
Im seeing that in the realtimeclient program.
  • Davis VP2
  • Android 5.0.1
  • Chrome 59.0.3071.125
    • Weather Display
« Reply #39 on: August 19, 2017, 02:57:09 AM »
With nothe other log info between the log offf attempts?
  • Mark
  • North Bend, WA
  • Win 7/Srvr 2008R2
« Reply #40 on: August 19, 2017, 03:26:31 AM »
It just happened. This is what was in the realtimeclient before I just restarted it...
Quote
Sending local version: "SSH-2.0-IP*Works! SSH Client v9.0".
Read remote version string: "SSH-2.0-OpenSSH_6.7p1 Debian-5+deb8u1~ui80+7".
Beginning key exchange
Preparing algorithm negotiation.
Sending local enabled algorithm list.
Reading remote enabled algorithm list.
Selected key exchange algorithm: "diffie-hellman-group14-sha1".
Selected server host key algorithm: "ssh-rsa".
Selected client encryption algorithm: "aes256-ctr".
Selected server encryption algorithm: "aes256-ctr".
Selected client MAC algorithm: "hmac-sha1".
Selected server MAC algorithm: "hmac-sha1".
Selected client compression algorithm: "none".
Selected server compression algorithm: "none".
Algorithm negotiation complete.
Sending Diffie-Hellman key exchange initialization request.
Verifying server's Diffie-Hellman key exchange response.
Diffie-Hellman key exchange complete. Calculating key sets.
Sending new key packet to server. Setting client keys.
Received new key packet from server. Setting server keys.
Key exchange complete.
Requesting service "ssh-userauth".
  • Davis VP2
    • Weather Display
« Reply #41 on: August 19, 2017, 09:54:58 AM »
that is very different information that you have provided before
its very hard to know what is what and when and why
  • Mark
  • North Bend, WA
  • Android 7.0
« Reply #42 on: August 19, 2017, 02:43:58 PM »
Its the same information as i posted on page 1 of this thread.
  • Davis VP2
    • Weather Display
« Reply #43 on: August 19, 2017, 07:01:07 PM »
yes,, but its different to what you posted just prior
which makes it all very confusing
so the problem is that the login does not complete sometimes randomly and the program gets stuck/hung up in that, yes?
  • Davis VP2
    • Weather Display
