Author Topic: Real time client *Fixed*  (Read 2234 times)
Offline BWX
  • Win NT 10.0
  • Chrome 58.0.3029.110
Re: Real time client
« Reply #15 on: June 13, 2017, 05:35:44 AM »
Probably not server side, prob Win 7 settings, check out the power options, make sure the PC
isnt shutting something down whilst at idle, Choose performance mode, then modify the settings
make sure everything stays either  on, at 100% or not set to suspend, namely the USB settings
Just go through each setting, you dont want the HDD to go sleep, not the USB, not the CPU etc
Offline ALITTLEweird1
  • Mark
  • Global Moderator
  • North Bend, WA
  • Win 7/Srvr 2008R2
  • Mozilla compatible
    • North Bend Weather
« Reply #16 on: June 15, 2017, 10:49:51 PM »
Strange, now my WD pc is doing the same thing..
FTP error..
Weather Display FTP/Internet vers 9.05
***Time/date***:3:47:09 PM 6/15/2017
Logging onto SFTP server....home252567151.1and1-data.host
[10060] Connection timed out
10060: [10060] Connection timed out
Doing abort procedure/program close...
But filezilla connects just fine.
Running build 47 on Win 7
"Nature can do without man, but man cannot do without nature."
Davis VP2 + VP2 Solar + Logitech Webcam
  • Mark
  • Global Moderator
  • North Bend, WA
  • Win 7/Srvr 2008R2
« Reply #17 on: June 15, 2017, 11:23:33 PM »
Just caught this in the realtimeclient before it closed itself...
Quote
Real time Clientraw FTP, vers 9.5
***Time/date***:4:21:59 PM 6/15/2017
Logging onto FTP server....home252567151.1and1-data.host
Connecting to FTP server.
Attempting to connect to server.
Failed to connect: [10060] Connection timed out
FTP error occured
FTP Uploading C:\wdisplay\webfiles\clientraw.txttemp - >clientraw.txt
143: Busy performing current action.
FTP Uploading C:\wdisplay\webfiles\clientrawextra.txttemp - >clientrawextra.txt
FTP Uploading C:\wdisplay\webfiles\clientrawhour.txttemp - >clientrawhour.txt
FTP Uploading C:\wdisplay\webfiles\clientrawdaily.txttemp - >clientrawdaily.txt
Logging off from server 4:22:20 PM
But its not actually uploading anything.
  • Mark
  • Global Moderator
  • North Bend, WA
  • Win 7/Srvr 2008R2
« Reply #18 on: June 16, 2017, 01:14:48 AM »
Well, it seems all that needed to be done was change to passive mode. Strange to me that this happened all of a sudden.
Passive mode was brought up by Brian in another post and I thought I had those checked, But I had missed 1 spot that caused the issue.
« Last Edit: June 16, 2017, 01:42:10 AM by ALITTLEweird1 »
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
Re: Real time client**Solved**
« Reply #19 on: June 16, 2017, 08:43:01 PM »
web site providers often change things at their end where it needs passive mode
  • Mark
  • Global Moderator
  • North Bend, WA
  • Win 7/Srvr 2008R2
« Reply #20 on: August 04, 2017, 12:28:16 AM »
Hi Brian. I'm still having the intermittent realtimeclient disconnecting on me. It's happened about 6 times today. The only way to get it going again is to close out the realtime and re-open it, then it starts right back up. I'm at a loss with this. I just updated to build 55 last night, but it was happening before the update. Below is what shows in the realtime if this means anything to you. Also, Could I send you my files for you too look at? Maybe I'm just missing a simple setting that I cant find. Thanks
Quote
Logging off from server 4:05:49 PM
OK
SFTP Uploading C:\wdisplay\webfiles\clientraw.txttemp - >clientraw.txt
OK
OK
Sending local version: "SSH-2.0-IP*Works! SSH Client v9.0".
Read remote version string: "SSH-2.0-OpenSSH_6.7p1 Debian-5+deb8u1~ui80+7".
Beginning key exchange
Preparing algorithm negotiation.
Sending local enabled algorithm list.
Reading remote enabled algorithm list.
Selected key exchange algorithm: "diffie-hellman-group14-sha1".
Selected server host key algorithm: "ssh-rsa".
Selected client encryption algorithm: "aes256-ctr".
Selected server encryption algorithm: "aes256-ctr".
Selected client MAC algorithm: "hmac-sha1".
Selected server MAC algorithm: "hmac-sha1".
Selected client compression algorithm: "none".
Selected server compression algorithm: "none".
Algorithm negotiation complete.
Sending Diffie-Hellman key exchange initialization request.
Verifying server's Diffie-Hellman key exchange response.
Diffie-Hellman key exchange complete. Calculating key sets.
Sending new key packet to server. Setting client keys.
Received new key packet from server. Setting server keys.
Key exchange complete.
Requesting service "ssh-userauth".
Service request "ssh-userauth" accepted.
Authenticating user for service "ssh-connection".
Requesting user's authentication mechanism list from SSH host.
Attempting password authentication.
Password authentication succeeded.
Successfully authenticated user for service "ssh-connection".
Attempting to open "session" channel
Logging off from server 4:36:14 PM
OK
Logging off from server 5:06:39 PM
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 60.0.3112.90
    • Weather Display
« Reply #21 on: August 12, 2017, 05:14:13 AM »
secure ftp means a lot more hoops to jump through and so a lot more things can do wrong
I do not use a secure ftp server myself so its hard to diagnose
one solution is to use a web site that can be updated with no need for FTP
i.e using HTTP instead
meteotemplate is one solution
  • Mark
  • Global Moderator
  • North Bend, WA
  • Win 7/Srvr 2008R2
« Reply #22 on: August 13, 2017, 09:25:36 PM »
Thanks for the response Brian.
I guess im a little confused by this. My regular FTP uploads work just fine, Im only having the issue with the realtime.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #23 on: August 13, 2017, 10:30:52 PM »
the real time ftp is a lot more frequent
i.e more chance things could go wrong
I would need access to your ftp server to be able to test
and I would need to be able to duplicate the problem here
  • Mark
  • Global Moderator
  • North Bend, WA
  • Win 7/Srvr 2008R2
« Reply #24 on: August 14, 2017, 01:33:15 AM »
If your willing to test it, just let me know what you need and I'll PM you the info. Thanks
  • Mark
  • Global Moderator
  • North Bend, WA
  • Android 7.0
  • Chrome 51.0.2704.106
« Reply #25 on: August 17, 2017, 03:23:33 AM »
If you have time Brian,  i can give you the info you need.  Just let me know.  Thanks
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #26 on: August 17, 2017, 03:28:11 AM »
but that is what I posted above
  • Mark
  • Global Moderator
  • North Bend, WA
  • Android 7.0
« Reply #27 on: August 17, 2017, 12:00:19 PM »
I will send you my info after work today.  With you doing this testing,  will it affect my website at all?
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #28 on: August 17, 2017, 06:38:16 PM »
what I can do is change the remote file names
  • Mark
  • Global Moderator
  • North Bend, WA
  • Android 7.0
« Reply #29 on: August 17, 2017, 10:51:02 PM »
Sounds good.  Ill be sending you the info in a couple hours.
