Author Topic: Real time client *Fixed*  (Read 2495 times)
Offline ALITTLEweird1
  • Mark
  • Global Moderator
  • North Bend, WA
  • Win 7/Srvr 2008R2
  • Mozilla compatible
    • North Bend Weather
« on: May 21, 2017, 04:48:34 PM »
Im getting this error on my parents WD using XP...
ERROR: Unrecognized Error at time/date 9:46:51 AM 5/21/2017
Connecting to FTP server.
OK
Connected.
SSH-2.0-OpenSSH_6.7p1 Debian-5+deb8u1~ui80+7
It says its connecting, but then it doesn't do anything. I had to change the server name to connect, and ever since that I cant connect the real time or any other ftp functions.
« Last Edit: August 21, 2017, 12:12:04 AM by ALITTLEweird1 »
"Nature can do without man, but man cannot do without nature."
Davis VP2 + VP2 Solar + Logitech Webcam
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 58.0.3029.110
    • Weather Display
Re: Real time client
« Reply #1 on: May 21, 2017, 08:17:32 PM »
it could be because windows XP does not have the latest secure FTP drivers etc
but have you tried setting to use passive mode
it could also be a firewall blocking it, or anti virus or similar
  • Mark
  • Global Moderator
  • North Bend, WA
  • Win 7/Srvr 2008R2
« Reply #2 on: May 21, 2017, 08:36:00 PM »
Oh, that's right... The realtime is now secure. Will the new secure realtime client work on XP build 80 and is there a download just for that?
I do have everything set to passive.
Id love to update my parents PC to win 7, but they live about 6 hours away.
  • Mark
  • Global Moderator
  • North Bend, WA
  • Win 7/Srvr 2008R2
« Reply #3 on: May 21, 2017, 08:46:45 PM »
I found this post of yours Brian...
Quote
[/try this update
http://www.weather-display.com/downloadfiles/clientrawrealtimeftp.zip
i.e vers 9.5quote]
Is this compatible with Build 80? If it is, will this solve all the FTP issues cause nothing is connecting to upload any files.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #4 on: May 21, 2017, 10:26:11 PM »
you can only try
  • Mark
  • Global Moderator
  • North Bend, WA
  • Win 7/Srvr 2008R2
« Reply #5 on: May 21, 2017, 10:41:37 PM »
I think im actually going to try and update their WD to the most current... crossing my fingers that works.
Cant really lose much at this point.
  • Mark
  • Global Moderator
  • North Bend, WA
  • Win 7/Srvr 2008R2
« Reply #6 on: May 23, 2017, 03:13:15 AM »
So loading the current build did not go good.
Brian, do you have a copy of build 80 or 81 so I can load that back up to get the registry files to be able to transfer my parents WD to Win 7?
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
  • Mark
  • Global Moderator
  • North Bend, WA
  • Android 7.0
  • Chrome 51.0.2704.106
« Reply #8 on: May 23, 2017, 11:54:38 AM »
  • Mark
  • Global Moderator
  • North Bend, WA
  • Win 7/Srvr 2008R2
« Reply #9 on: June 10, 2017, 02:57:15 PM »
I got a new pc for my parents and loaded the latest version of WD. Now every now and then t he real time client stops uploading and shows this..
Quote
Logging off from server 3:50:37 AM
Logging off from server 4:21:02 AM
Logging off from server 4:51:27 AM
Logging off from server 5:21:52 AM
Logging off from server 5:52:18 AM
Logging off from server 6:22:43 AM
Logging off from server 6:53:08 AM
Logging off from server 7:23:33 AM
If I close down the realtime and open it back up, it works fine. Any ideas why it just stops? My realtime client version is 9.5
The ftplog is attached.
  • Mark
  • Global Moderator
  • North Bend, WA
  • Win 7/Srvr 2008R2
« Reply #10 on: June 10, 2017, 07:23:46 PM »
Just got this when it stopped uploading..
Quote
Logging off from server 11:55:53 AM
OK
Doing abort procedure/program close...
SFTP Uploading C:\wdisplay\webfiles\clientraw.txttemp - >clientraw.txt
OK
OK
Sending local version: "SSH-2.0-IP*Works! SSH Client v9.0".
Read remote version string: "SSH-2.0-OpenSSH_6.7p1 Debian-5+deb8u1~ui80+7".
Beginning key exchange
Preparing algorithm negotiation.
Sending local enabled algorithm list.
Reading remote enabled algorithm list.
Selected key exchange algorithm: "diffie-hellman-group14-sha1".
Selected server host key algorithm: "ssh-rsa".
Selected client encryption algorithm: "aes256-ctr".
Selected server encryption algorithm: "aes256-ctr".
Selected client MAC algorithm: "hmac-sha1".
Selected server MAC algorithm: "hmac-sha1".
Selected client compression algorithm: "none".
Selected server compression algorithm: "none".
Algorithm negotiation complete.
Sending Diffie-Hellman key exchange initialization request.
Verifying server's Diffie-Hellman key exchange response.
Diffie-Hellman key exchange complete. Calculating key sets.
Sending new key packet to server. Setting client keys.
Received new key packet from server. Setting server keys.
Key exchange complete.
Requesting service "ssh-userauth".
Service request "ssh-userauth" accepted.
Authenticating user for service "ssh-connection".
Requesting user's authentication mechanism list from SSH host.
OK
Real time Clientraw FTP, vers 9.5
***Time/date***:12:20:20 PM 6/10/2017
Logging onto SFTP server....home3476.1and1-data.host
143: Busy performing current action.
« Last Edit: June 10, 2017, 07:48:05 PM by ALITTLEweird1 »
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #11 on: June 10, 2017, 08:06:38 PM »
I see you are using secure FTP (SSH)
which adds another layer of complexity and things that can go wrong
  • Mark
  • Global Moderator
  • North Bend, WA
  • Android 7.0
« Reply #12 on: June 10, 2017, 08:13:39 PM »
Interesting.... i did not know that.  Ill double check my settings.
  • Mark
  • Global Moderator
  • North Bend, WA
  • Android 7.0
« Reply #13 on: June 10, 2017, 08:17:58 PM »
I unchecked the ssh in the real-time settings tab.  So far so good,  ill keep an eye on it.
  • Mark
  • Global Moderator
  • North Bend, WA
  • Win 7/Srvr 2008R2
« Reply #14 on: June 13, 2017, 12:54:24 AM »
Here's where everything stands as of now...
My parents site and mine are on the same host "1and1." I made sure that their settings for FTP are the same as mine. What's happening is on my parents site, the realtimeclient seems to stop updating about every 7 to 9 mins, then it starts again. My site does not do that and our settings are the same.
So, do you think its a server issues, or internet?
I have cable internet and they have satellite.
And, just an FYI to this issue.. As of last month they were still running build 81 without this issue. This only started after updating to Win 7 with the latest WD build.
