Author Topic: indoor humidity plot  (Read 1634 times)
Offline BWX
  • Win NT 10.0
  • Chrome 57.0.2987.133
« on: April 18, 2017, 10:33:06 AM »
Hello, i cannot find how you change the scale for the indoor humidity? I am trying to plot my davis soil moisture and it looks like it has to use the indoor humidity, it looks like it also plots behind the blocked in solar so you cant see the soil when using the indoor humidity, Am i doing something wrong please
Online Weather Display
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
Re: indoor humidity plot
« Reply #1 on: April 18, 2017, 07:58:52 PM »
currently you can not change the scale
but I could add that ability for this function selection
Offline BWX
  • Win NT 10.0
« Reply #2 on: April 19, 2017, 04:57:58 AM »
Thank you for the reply,  Phew, i thought it was my eyes/brain failing me. It would be useful, but, only when you get around to it, thank you.
Offline BWX
  • Win NT 10.0
  • Chrome 58.0.3029.81
« Reply #3 on: April 28, 2017, 11:50:15 AM »
Hello Brian, did this get implemented at all, not rushing you, just bringing it back up in case you may have forgotten about it, also about it being hidden behind the solar when solar is set to blocked in. Thank you
Offline BWX
  • Win NT 10.0
  • Chrome 58.0.3029.110
« Reply #4 on: June 05, 2017, 06:13:10 AM »
Hello, this had fallen down 3 pages, thought i would do a cheeky bump, sorry  :oops:
Quote from: BWX on 28-04-2017, 12:50:15<blockquote>Hello Brian, did this get implemented at all, not rushing you, just bringing it back up in case you may have forgotten about it, also about it being hidden behind the solar when solar is set to blocked in. Thank you
</blockquote><blockquote>
</blockquote>
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 59.0.3071.115
    • Weather Display
« Reply #5 on: July 27, 2017, 06:24:32 AM »
the axis will change to 200
when the soil moisture is over 100
is the problem that it needs to go higher for when the soil moisture of over 200?
Offline BWX
  • Win NT 10.0
  • Chrome 60.0.3112.78
« Reply #6 on: July 27, 2017, 07:39:35 AM »
Hello, thank you for the reply, at the moment the plot is too far up the graph, i would like to be able to adjust it so that it is much lower down the graph, also the plot is hidden when the solar is set to blocked in so you cannot see it and as the indoor humidity is the same colour as the solar you cannot see where on starts and the other one ends.
Added an image, i hope it helps
« Last Edit: July 27, 2017, 08:17:36 AM by BWX »
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #7 on: July 27, 2017, 06:33:27 PM »
you should be able to change the colour of the plot, i,e by setting the indoor humidity colour
I cant do anything about it being behind the solar plot though (being above the solar fixes that problem so not sure why you would want it lower?)
Offline BWX
  • Android 5.0
  • Chrome 59.0.3071.125
« Reply #8 on: July 27, 2017, 07:33:15 PM »
Hello, indoor humidity is the same colour setting as the solar, both have to be the same. As a last resort I will not use the solar blocked in, the reason for wanting the scale lower is because it looks odd and out of place up there with the temperature, not only that, it can clash with the other posts, but once the soil dried out some and the plot lowers it will override the temp and humidity levels plots, more so as the moisture is a slow moving, that's why ideally it would be better much lower, tucked out of the way but still see able at a glance.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #9 on: July 28, 2017, 08:17:11 PM »
you should be able to set the colours different from each other (i.e use the solar blocked and or solar blocked to /from)
Offline BWX
  • Win NT 10.0
« Reply #10 on: July 29, 2017, 04:46:48 AM »
Hello, ok, i will give that a try, thank you
Back to the original question, would you still be able to add this please?
Quote<blockquote>currently you can not change the scale
but I could add that ability for this function selection</blockquote>
« Last Edit: July 29, 2017, 05:25:18 AM by BWX »
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #11 on: July 29, 2017, 08:08:51 PM »
what specificly do you need?
start and end?
Offline BWX
  • Android 5.0
« Reply #12 on: July 29, 2017, 08:35:16 PM »
Hello, basically, to be able to adjust it like you can with
The other plots, such as the outdoor temp please.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #13 on: July 29, 2017, 08:45:48 PM »
do you mean being able to set a min/max scale?
Offline BWX
  • Win NT 10.0
« Reply #14 on: July 30, 2017, 04:46:54 AM »
Hello, yes, that is correct.
