Author Topic: Add Acurite soil - water sensors  (Read 1298 times)
Offline ke9lz
  • Win NT 10.0
  • Chrome 57.0.2987.133
« on: April 06, 2017, 04:09:22 PM »
Hi,    I recently purchased a AcuRite 00275RM Outdoor temp and Humidity sensor as well as the add on soil temp sensor and also use Meteobridge to feed WD.  I can see this if I query Meteobridge and this is what I see :
 <logger>
<TH date="20170328140130" id="th0" temp="4.7" hum="88" dew="2.9" lowbat="0"/>
<WIND date="20170328140147" id="wind0" dir="113" gust="0.0" wind="0.1" chill="4.7" lowbat="0"/>
<THB date="20170328140155" id="thb0" temp="0.0" hum="0" dew="0.0" press="984.8" seapress="1021.3" fc="-1" lowbat="0"/>
<TH date="20170328140123" id="th5" temp="3.7" hum="90" dew="2.2" lowbat="0"/>
<RAIN date="20170328140111" id="rain0" rate="0.0" total="0.0" delta="0.0" lowbat="0"/>
<TH date="20170328140105" id="th6" temp="5.1" hum="56" dew="-3.0" lowbat="0"/>
<T date="20170328140028" id="t11" temp="1.6" lowbat="0"/>
<TH date="20170328140121" id="th7" temp="11.7" hum="31" dew="-4.9" lowbat="0"/>
</logger>
The first data is from a 5 in 1, the second which is TH5 is a 00609A1TXR temp humidity sensor, TH6 is the 00275RM Outdoor temp and Humidity sensor with the add on soil temp probe which is given the id of t11 and TH7 is another  00609A1TXR temp humidity sensor.  My question is can this be added to WD so that it can be used?  I have no problems adding the TH5 and TH6 and TH7 to WD but since the soil probe is given an id of t11 I don't see a way to add it.  Also, I have found that if I take the 2 00609A1TXR temp humidity sensors away and just have the 00275RM Outdoor temp and Humidity sensor on line it is given a TH5 id as well as T10 for the soil temp id so as more are added the soil temp is given a higher number from 10.  Is this something that can be added?
Thanks,  Steve
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
Re: Add Acurite soil - water sensors
« Reply #1 on: April 06, 2017, 08:20:49 PM »
WD should be picking that up as  VP soil temp 4
Offline ke9lz
  • Win NT 10.0
« Reply #2 on: April 07, 2017, 01:19:00 PM »
     I took a look at vp soil temp 4 using view panel - Davis VP/Vue Extra sensor info and find soil temp 4 blank as well as no indication of it anywhere on the clientraw file.  Am I missing it some where else?  Ultimately, I would like to use that data in my web site templete which uses clientraw field #14 but doesn't have to be as long as it's available in the clientraw.txt file.
Steve
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #3 on: April 07, 2017, 06:29:50 PM »
you can enable extra debug info
do that under setup , advanced/misc...log the raw data
then see what shows under view, debug info, for that sensor ID number
Offline ke9lz
  • Win NT 10.0
« Reply #4 on: April 08, 2017, 02:52:10 PM »
Here is what the debug info looks like :
whole raw <logger>
<TH date="20170408144218" id="th7" temp="23.8" hum="30" dew="5.2" lowbat="0" />
<THB date="20170408144236" id="thb0" temp="0.0" hum="0" dew="0.0" press="975.0" seapress="1011.1" fc="-1" lowbat="0" />
<TH date="20170408144210" id="th6" temp="10.7" hum="37" dew="-3.4" lowbat="0" />
<T date="20170408144134" id="t11" temp="7.7" lowbat="0" />
<RAIN date="20170408144215" id="rain0" rate="0.0" total="0.0" delta="0.0" lowbat="0" />
<TH date="20170408144232" id="th5" temp="12.9" hum="35" dew="-2.2" lowbat="0" />
<TH date="20170408144121" id="th0" temp="11.4" hum="83" dew="8.6" lowbat="0" />
<WIND date="20170408144215" id="wind0" dir="113" gust="1.3" wind="1.1" chill="11.4" lowbat="0" />
</logger>
" temp="23.8" hum="30" dew="5.2" lowbat="0" />  <T
yes extra temp 7 24
yes extra hum 7
yes indoor temp
yes indoor hum
yes baro
" temp="10.7" hum="37" dew="-3.4" lowbat="0" />  <
yes extra temp 6 11
yes extra hum 6
*******soil temp 4 sensor found
yes soil temp 4
" rate="0.0" total="0.0" delta="0.0" lowbat="0" />  <TH date
yes total rain
" temp="12.9" hum="35" dew="-2.2" lowbat="0" />  <
yes extra temp 5 13
yes extra hum 5
" temp="11.4" hum="83" dew="8.6" lowbat="0" />  <W
yes outdoor temp
yes outdoor hum
yes dir
yes gust
yes wind
Not sure what I am seeing but it appears that it knows it's there.
Steve
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #5 on: April 08, 2017, 06:35:15 PM »
Quote
yes soil temp 4
it is picking it up OK
try putting the vpsoiltemp4 custom tag somewhere so you can see that data?
Offline ke9lz
  • Win NT 10.0
« Reply #6 on: April 10, 2017, 04:53:48 PM »
Ok, I was able to find it now and is working.  Thanks for pointing me in the right direction.  Is it possible to change the sensor from being number 4 to being the first one?
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #7 on: April 10, 2017, 06:40:40 PM »
the problem is , there is already provision for VP soil temp 1
I do have in the setups where you can map different extra temp sensors to different ones (i.e like re number)
I cant remember off hand if you can do what you need (I think not). see under setup, advanced/misc, extra temp
why did you want to remap it?
Offline ke9lz
  • Win NT 10.0
« Reply #8 on: April 12, 2017, 02:32:37 PM »
Ok this shouldn't be a problem that I can't work out.  I use Scotts alternate dashboard and it allows you to display the VP soil sensors but with the Acurite sensors as he has the dashboard written it won't work.  This won't really be a problem as it can be modified to work.  I was just looking for an easy way to use what was there.  I did try the remap but was unable to get it working.  The only other question I would have is how many of these sensors would I be able to use until WD won't see them?
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #9 on: April 13, 2017, 07:43:19 AM »
up to sensor 11 is the max that WD checks for
you should be able to modify the dashboard html code to use the custom tag for the VPsoiltemp4 I would think
Offline ke9lz
  • Win NT 10.0
« Reply #10 on: April 18, 2017, 04:32:40 PM »
I have been able to use VPsoiltemp4 and is working nicely.  Thanks for the pointers.
Steve
