Author Topic: Which USB-Serial Adapter and driver for ElCap  (Read 5012 times)
Offline sdjones
  • Ontario
  • Mac OS X 10.12.4
  • Safari 10.1
    • http://weather.mikeoxlong.net
Re: Which USB-Serial Adapter and driver for ElCap
« Reply #15 on: March 21, 2017, 01:34:35 AM »
You got it!
  • Davis VP2
  • Chrome 56.0.2924.87
    • Weather Display
« Reply #16 on: March 21, 2017, 04:03:36 AM »
that's good  :wink:
you can turn off the debug setting
Offline sdjones
  • Ontario
  • Mac OS X 10.12.4
  • Safari 10.1
« Reply #17 on: March 22, 2017, 01:59:17 AM »
Next problem is how to release the comm port when the program exits?
I've tried using the Exit menu item and I've tried going into the Control Panel and closing the comm port but nothing works.  The comm port stays open and locked.
If you try to restart the program, you get the spinning beach ball.
The only way to release the comm port is to reboot the computer.
  • Davis VP2
    • Weather Display
« Reply #18 on: March 22, 2017, 06:18:14 PM »
I will upload version 283 which should fix that hopefully
Offline sdjones
  • Ontario
« Reply #19 on: March 23, 2017, 01:16:49 AM »
Thanks again.
There's a bunch of other stuff happening with the data which might be due to the parsing of the stream but I'll hold off on that for now.
Offline sdjones
  • Ontario
  • Mac OS X 10.12.4
  • Safari 10.1
« Reply #20 on: March 25, 2017, 05:57:26 PM »
283 seems to have fixed the serial port closure issue.  Thanks.
I've got some funkiness happening with some readings not showing up and the graph no updating with any of the wind readings.
I've included a screenshot of the OSX and Windows screens side by side.
The Average Wind Speed isn't updating, the windchill is wrong (due to wind speed?), the maximum gusts are wrong, the maximum temperature is wrong and the minimum temperature is wrong.  You can also see the timestamp for the temperature readings is wrong.
The OSX version has just been running a few minutes and the Windows version has been running for quite a few days now.
  • Davis VP2
    • Weather Display
« Reply #21 on: March 25, 2017, 11:51:38 PM »
do you mean you are using a Y splitter?
Offline sdjones
  • Ontario
« Reply #22 on: March 26, 2017, 12:45:17 AM »
Yes, both machines are fed the same data stream through a y cable.
  • Davis VP2
    • Weather Display
« Reply #23 on: March 26, 2017, 03:58:47 AM »
I should be able to fix the average speed not working
I suspect that there might be some data packets missed (i.e missed syncing) ,re the max gust
  • Davis VP2
    • Weather Display
« Reply #24 on: March 28, 2017, 09:53:45 PM »
try, re the average speed, as a test:
http://www.weather-display.com/downloadfiles/weatherdisplaymaczip.zip
and unzip that exectutable file to the
/Applications/weatherdisplay.app/Contents/MacOS/
folder
I only have a console here, no actual windspeed or temp/hum unit (but I might be able to get that at some stage to help in testing/improvements)
Offline sdjones
  • Ontario
  • Mac OS X 10.12.4
  • Safari 10.1
« Reply #25 on: April 01, 2017, 05:02:03 PM »
Sorry but no difference.
Average Wind Speed isn't changing, most of the graphs aren't plotting and my Maximum and Minimum Temperatures aren't changing and show no timestamp.
  • Davis VP2
    • Weather Display
« Reply #26 on: April 01, 2017, 08:58:29 PM »
humm
what I will need to try and do (since I do not have all the hardware) is spoof that I have actual data
if you set to log the raw data...see under setup, advanced/misc
and then email me the rawultimeterdata.txt file that should be created
  • Davis VP2
    • Weather Display
« Reply #27 on: April 03, 2017, 02:03:20 AM »
try a new full download of the latest mac version (build 284)
Offline sdjones
  • Ontario
  • Mac OS X 10.12.5
  • Safari 10.1.1
« Reply #28 on: April 04, 2017, 12:34:53 PM »
After about 5 minutes, I can see an Average Wind Speed.  What time period is that based on?  I'll let it run and compare it to the Windows version after it's accumulated more data.
The Maximum Temperature is now showing with a timestamp but Minimum Temperature doesn't seem to be updating and I'm not seeing a timestamp for it.
I'm also not seeing Yesterday's rain total.
Graphs now appear to be updating as well.
Great progress!
  • Davis VP2
    • Weather Display
« Reply #29 on: April 04, 2017, 06:40:17 PM »
its a rolling average, calculated at every update (last 60 readings)
