do you have a picture/link to the station?
does it have a console?
that looks like yet another new model
they might have changed the protocol yet again
does the heavy weather software wireless version work with it?
have you tried selecting the WiFi Pro station type in WD and ticked to use the direct wireless option?
Where is this option? Im looking in WD and do not see it.
control panel
weather station type
stationless/wifi pro tab
tick wifi pro and then tick to the right of that
see attached screen shot
The version i downloaded yesterday does not have that option, I will try and download another version
It’s getting some data but not all, any suggestions?
Here is how i have the settings:
Why didn’t you check “Use via wifi direct” as suggested?
It is checked now.
Still not getting wind speed, or rainfall. it is currently raining hard here, so I know both should be registering.
I appreciate any other suggestions
edited to add image
you need to untick all those other settings you have set for the Wifi pro station
only tick settings that you know you need
then click on save,then restart WD
unticked and restarted still no windspeed or rainfall
what now shows across the top of the WD program
and also re post a screen shot of how you have the weather station type setup
also what shows under view, debug info?
Ill post screenshot after dinner. Thanks for helping me get this far.
I notice that it’s not updating displaying live data just data from when I restarted WD.
Current Screenshot:
Current Settings:
you still have a setting ticked that you should not have ticked
in the wifi server->client settings
untick that
then click on save
then restart WD
and then let me know what shows under view , debug info
also note that default data is showing only
Now I’m getting no data:
Debug info:
Daylight saving not in use
Loaded all time records
Connection failed com port 1
Does anyone know if there is a way to capture the data from this to see if it can be used with WD seeing as I have the station I can try what may be suggested. It auto-sends data to WU and WeatherCloud. Theres got to be a way to hijack this data and figure out how to get in into WD.
This appears to be a clone of a Fine Offset WH2900 http://www.foshk.com/Wifi_Weather_Station/WH2900.html maybe this information will help out.
you were not actually getting any data before…WD was just showing default start up data
there was no guarentee this new model was going to work
as they seem to come out with a new weather station model every year that has a different data protocol
Hello, now one year after, Does anyone know if there is a way to capture the data from model wh2900 to see if it can be used with WD seeing as.
