Thanks, according to an app I just downloaded, would you Adam and Eve it, from the bottom of the speed to the bottom of the mount on the mast it’s spot on 45 degrees, so it I place it a foot below then that, in theory, should be ok?
If I’m understanding you right - yes, you should be OK. In the south of England you have more than 45 degrees to play with anyway, more like a nudge over 50. You aren’t going to register sunshine for a period just after sunrise and just before sunset anyway.
Thanks Mark, appreciate the info…
The anemometer stick should face north so I’m confused by the calibration comment. If you mount it that way, and mount the solar/UV on the south side of the mast at a similar height there should be no problem :?
I am facing it south, therefore i need to calibrate it to suit…
I have overlooked one major thing though, i though all cables were 4 core, nope, temp/hum is 5 or 6 core, couldnt see properly
its getting dark, thats a bummer cause i have already buried the cable
now i have to find somewhere tomorrow that has 6 core cable, pref same colour s and some 6 pin rj11’s
Why do you need a long 6 core?
To go from temp to the transmitter, transmitter is now on the mast, temp is were OS temp is in the middle
It was easier doing it that way than having 3 cables from the mast to the temp UV/solar/wind, my way its only 1 cable temp to mast
Its RJ11 6P6C i need aint it RJ11 6P4C is for th other cables right?
I would not recommend separating the temp/hum farther from the transmitter, not a good idea IMHO. That’s why the replacement rain gauge base is a really convenient way to split the gauge, it has both shelter and transmitter mount.
Ah, too late of that lol
Why not? Its just to extend the 6-core cable like the 4-core one. Nothing special there. Done that w/o problems.
One reason for splitting them apart are also so it not builds up ice between rainpot and temp/hum during the winter whats could break it.
Just FYI, its quite odd Davis not have taken in account that ice-build-thingy in the first place…
Interesting, what distance?
My concern is the VP2 temp/hum uses more complex digital communication interface than the simple switch closure/variable resistance of the anemometer and rain gauge. But I guess it’s not an issue after all
Ice build up, in California? :lol:
Some 5-6 m.
No, but up here with heated gauge yes
First winters with they untouched had i to try to get away that ice to not break the thing but also because it clogged the water-holes in the bottom of the rainpot at the end. So it is a really crap design by default.
I seem to recall that at one time the humidity sensor worked like a variable capacitor, and the capacitance measuring circuit was on the SIM board. Adding extra cable was not recommended because that could alter the capacitance. Is it not like that any more?
N7XSQ
I will be going 10m’s, if not then i will have to mount it on the mast and that i didnt want to
do due to the heat off the summer house roof
As it stands, i cannot find any 6 core connectors locally anyway
No, it’s a totally digital sensor now, SHT11 until recently, now SHT31 I think. It uses 2 wire serial comm similar to I2C which is usually only used for on board or board to board interface, but apparently it works over longer distances.
IS that gonna be too long?
Don’t know. Based on the chip’s datasheet I’m surprised 5-6 m works for weatherc so all bets are off :dontknow:
oh well, only one way to find out going the other way would cost a fortune in cable x3
Ald old thread about the subject: http://www.weather-watch.com/smf/index.php?topic=48099.0
EDIT: Anoher one whre Sensirion have answered 3-10 m should be fine: http://www.wxforum.net/index.php?topic=14091.0
