Ok, and how can you solve? Itâs possible configure the file âconfig.phpâ to be able to put km/h defalut?
Thank you
Mine is working now for some reason, panic over, thanks anyway
Thank you very much Henkka.
Steve
No, you canât configure config.php to do that.
You should un-checked âcookies and other dataâŚâ in navigation data menu on chrome browser
Cheers,
Alessandro
tried $path_to_langfiles = âlang/â; the button still work
their is not a lang folder in the wxsim folder only lang info is in the config file itâs self
the lastret.txt is in the root folder http://ballaugh.no-ip.biz:2082/lastret.txt
the local server is a synology 214 with web server and the root folder I load into is called web
I tried $path_to_lastret = âhttp://ballaugh.no-ip.biz:2082/lastret.txtâ;
also $path_to_lastret = âhttp://ballaugh.no-ip.biz:2082/web/lastret.txtâ; neither changed the top updated time from 01.01.1970 01:00 to the correct value
only $path_to_lastret = ââŚ/lastret.txtâ; works and gives the correct date and time for the last updated lastret.txt file in the root folder
Harold
It showed 9 days on my dev-version.
Feel free to test the updated zip
- Default units should be read from $uoms
- Possibility to set rain-unit from the unit-gear
// Henkka
Henkka, this is great. All the units are now working as defined by $UOM. Thanks for doing this.
There does appear to be one issue. For the last several days at the end of the Carousel Forecast, it is showing 14-plus inches of rain. This is far greater than it should be or what lastret.txt is showing. My webpage is here: http://tylertexasweather.com/ttwfcast4.htm and the current lastret.txt is here: http://tylertexasweather.com/lastret.txt
Steve
Mone is looking pretty good with the latest update but I canât get the weather description to come up. Only says null.
You can see here: http://www.shermanctweather.org/ewn/wxsim/forecast.php
Iâve attached a copy of my lastret.txt
Tom
lastret.txt (50.1 KB)
Great with a lastret.txt in US-units to test with
I allready found the 14+ inches issue.
Btw. enable relative humidity on WRET (dewpoint are else wrong)
Zip updated with fix for the inch-rain
Mone is looking pretty good with the latest update but I can't get the weather description to come up. Only says null. You can see here: http://www.shermanctweather.org/ewn/wxsim/forecast.php I've attached a copy of my lastret.txt
Could you post your plaintext.txt?
Henkka,
I tried the latest update. The good news is that it did fix the excessive rain amounts. The bad news is that it broke the temperatures. Itâs now taking the Farenheit temperature and assuming it is Celsius, then converting it to Farenheit. So my 66 degrees becomes 151 degrees. Youâll see it here: http://tylertexasweather.com/ttwfcast4.htm.
Also, there is a problem with the rain totals in the table. It appears the rain amount listed is for perhaps 1 hour when it should be a 12-hour total for either the day or night. For example, we are expecting rain Sunday and Monday. Currently the table is showing 0.01 in on Sunday, 0.03 in on Sunday night, and 0.01 in on Monday. What it should read is something like, for example, 0.25 in on Sunday, 0.75 in on Sunday night, and 0.25 in on Monday.
FYI, Iâve updated my WRET with humidity. You can see my current lastret.txt here: http://tylertexasweather.com/lastret.txt
Steve
I tried the latest update. The good news is that it did fix the excessive rain amounts. The bad news is that it broke the temperatures. It's now taking the Farenheit temperature and assuming it is Celsius, then converting it to Farenheit. So my 66 degrees becomes 151 degrees. You'll see it here: http://tylertexasweather.com/ttwfcast4.htm.
Check the $uoms in config.php, seems to be metric.
Henkka,
The $uoms looks correct to me.
#$uoms = array('C','mm','km/h','hPa','cm','km');
$uoms = array('F','in','mph','inHg','in','mi');
Steve
Hi Henkka,
Sorry late response, checked all Lat /Lon settings all correct.
I did some searching on the net and found those 2 scripts to be slightly flawed, also checked your site and TylerTexas (both showing incorrect Moon (Rise/Set) Times also.
Not sure what the answer is.
Also just noticed that UV is not utilized, would UV be difficult to add as it was in the 3in1.
Kind regards,
Yep. But source-code of http://tylertexasweather.com/wxsim-ewn/forecast.php have theese:
var snowset="cm",baroset="hPa",wiset="ms",piset="mm",tiset="c";
so it seems it reads them from some other file.
I did some searching on the net and found those 2 scripts to be slightly flawed, also checked your site and TylerTexas (both showing incorrect Moon (Rise/Set) Times also. Not sure what the answer is.
I havenât âquality-chekcedâ them so it its fully possible. They was the only one i found for the moon-stuffs. I someone finds any better working with PHP will i happily do a switch.
It shouldnât be difficult. Why they are not there are that there are no UV-data in the EWN forecast-data so there was no UV-row in the orginal script + also that no UV at this time of the year up here so been difficult to test it.
// Henkka
Hi Henkka,
Not sure if I can help with an alternative script - I have used the following (attached: sunmoon.php.txt) in the past which is returns correct times, though not sure if you could adapt it.
Should return an array similar to this :
Array ( [solarNoon] => DateTime Object ( [date] => 2017-02-19 13:27:22.000000 [timezone_type] => 3 [timezone] => Australia/Hobart ) [nadir] => DateTime Object ( [date] => 2017-02-19
01:27:22.000000 [timezone_type] => 3 [timezone] => Australia/Hobart ) [sunrise] => DateTime Object ( [date] => 2017-02-19 06:39:16.000000 [timezone_type] => 3 [timezone] => Australia/Hobart )
[sunset] => DateTime Object ( [date] => 2017-02-19 20:15:29.000000 [timezone_type] => 3 [timezone] => Australia/Hobart ) [sunriseEnd] => DateTime Object ( [date] => 2017-02-19 06:42:19.000000
[timezone_type] => 3 [timezone] => Australia/Hobart ) [sunsetStart] => DateTime Object ( [date] => 2017-02-19 20:12:26.000000 [timezone_type] => 3 [timezone] => Australia/Hobart ) [dawn] => DateTime
Object ( [date] => 2017-02-19 06:09:18.000000 [timezone_type] => 3 [timezone] => Australia/Hobart ) [dusk] => DateTime Object ( [date] => 2017-02-19 20:45:27.000000 [timezone_type] => 3 [timezone]
=> Australia/Hobart ) [nauticalDawn] => DateTime Object ( [date] => 2017-02-19 05:33:00.000000 [timezone_type] => 3 [timezone] => Australia/Hobart ) [nauticalDusk] => DateTime Object ( [date] => 2017-
02-19 21:21:44.000000 [timezone_type] => 3 [timezone] => Australia/Hobart ) [nightEnd] => DateTime Object ( [date] => 2017-02-19 04:54:09.000000 [timezone_type] => 3 [timezone] => Australia/Hobart )
[night] => DateTime Object ( [date] => 2017-02-19 22:00:36.000000 [timezone_type] => 3 [timezone] => Australia/Hobart ) [goldenHourEnd] => DateTime Object ( [date] => 2017-02-19 07:17:45.000000
[timezone_type] => 3 [timezone] => Australia/Hobart ) [goldenHour] => DateTime Object ( [date] => 2017-02-19 19:37:00.000000 [timezone_type] => 3 [timezone] => Australia/Hobart ) )
Array ( [fraction] => 0.48381924324166 [phase] => 0.75515139425707 [angle] => 1.7675452111715 )
Array ( [moonrise] => DateTime Object ( [date] => 2017-02-19 00:08:07.000000 [timezone_type] => 3 [timezone] => Australia/Hobart ) [moonset] => DateTime Object ( [date] => 2017-02-19
14:31:06.000000 [timezone_type] => 3 [timezone] => Australia/Hobart ) )
Also: That would be excellent if we could get the UV included, if it is on any assistance I have (attached my : lastret.txt) which always has ( UVI and S.IR ) here in Tasmania.
Kind regards,
lastret.txt (105 KB)
sunmoon.php.txt (9.87 KB)
I have downloaded latest version and itâs mostly working. It can be seen here:
My only problem is I canât get description to work. Iâm not sure if that has anything to do with the folder âlangâ.
My lastret can be seen here:
http://www.shermanctweather.org/lastret.txt
I havenât really figured out where that folder âlangâ comes from.
Tom
Hi Tom,
What seems to be missing is your âplaintext.txtâ file, I see it is in same directory as your âlastret.txtâ file, so the path to it must be incorrect in your other files.
The file âplaintext.phpâ In directory: âŚwxsim/wxsim/plaintext.php should be setup as per attached : so it finds the âplaintext.txtâ file.
Unless of course you have modified the other scripts and changed the path structure for looking up âlastret.txtâ
regards,
plaintext.php.txt (19.5 KB)
Tony,
My plaintext.txt file is in my root directory where my lastret.txt is also.
I copied your plaintext.php but it still doesnât work. The only file Iâve changed is the config file.
I put a copy of the plaintext.txt in âŚwxsim/wxsim folder but no success.
Iâm still confused.
Thanks for trying to help.
Tom
