Have you already checked wret?
HI, it cant be wret either cause my other scripts are going to 9 days too
Bashy, check the lastret.txt and be sure it have 00:00 timestamps. If you post your lastret.txt can i run it in m y dev-version and see if there are any oddities.
Btw. I have rain-units working on my dev-version now.
I think i will also get it so it reads the default units from $uoms
Thanks, here ya go, knowing me, it will be a rookie mistake but this does work for your
other scripts
lastret.txt (91 KB)
ok, now im officially lost, that one i posted is 9 days, this one thats uploaded is only 3
Ok, and how can you solve? It’s possible configure the file “config.php” to be able to put km/h defalut?
Thank you
Mine is working now for some reason, panic over, thanks anyway
Thank you very much Henkka.
Steve
No, you can’t configure config.php to do that.
You should un-checked “cookies and other data…” in navigation data menu on chrome browser
Cheers,
Alessandro
tried $path_to_langfiles = “lang/”; the button still work
their is not a lang folder in the wxsim folder only lang info is in the config file it’s self
the lastret.txt is in the root folder http://ballaugh.no-ip.biz:2082/lastret.txt
the local server is a synology 214 with web server and the root folder I load into is called web
I tried $path_to_lastret = “http://ballaugh.no-ip.biz:2082/lastret.txt”;
also $path_to_lastret = “http://ballaugh.no-ip.biz:2082/web/lastret.txt”; neither changed the top updated time from 01.01.1970 01:00 to the correct value
only $path_to_lastret = “…/lastret.txt”; works and gives the correct date and time for the last updated lastret.txt file in the root folder
Harold
It showed 9 days on my dev-version.
Feel free to test the updated zip
- Default units should be read from $uoms
- Possibility to set rain-unit from the unit-gear
// Henkka
Henkka, this is great. All the units are now working as defined by $UOM. Thanks for doing this.
There does appear to be one issue. For the last several days at the end of the Carousel Forecast, it is showing 14-plus inches of rain. This is far greater than it should be or what lastret.txt is showing. My webpage is here: http://tylertexasweather.com/ttwfcast4.htm and the current lastret.txt is here: http://tylertexasweather.com/lastret.txt
Steve
Mone is looking pretty good with the latest update but I can’t get the weather description to come up. Only says null.
You can see here: http://www.shermanctweather.org/ewn/wxsim/forecast.php
I’ve attached a copy of my lastret.txt
Tom
lastret.txt (50.1 KB)
Great with a lastret.txt in US-units to test with
I allready found the 14+ inches issue.
Btw. enable relative humidity on WRET (dewpoint are else wrong)
Zip updated with fix for the inch-rain
Mone is looking pretty good with the latest update but I can't get the weather description to come up. Only says null. You can see here: http://www.shermanctweather.org/ewn/wxsim/forecast.php I've attached a copy of my lastret.txt
Could you post your plaintext.txt?
Henkka,
I tried the latest update. The good news is that it did fix the excessive rain amounts. The bad news is that it broke the temperatures. It’s now taking the Farenheit temperature and assuming it is Celsius, then converting it to Farenheit. So my 66 degrees becomes 151 degrees. You’ll see it here: http://tylertexasweather.com/ttwfcast4.htm.
Also, there is a problem with the rain totals in the table. It appears the rain amount listed is for perhaps 1 hour when it should be a 12-hour total for either the day or night. For example, we are expecting rain Sunday and Monday. Currently the table is showing 0.01 in on Sunday, 0.03 in on Sunday night, and 0.01 in on Monday. What it should read is something like, for example, 0.25 in on Sunday, 0.75 in on Sunday night, and 0.25 in on Monday.
FYI, I’ve updated my WRET with humidity. You can see my current lastret.txt here: http://tylertexasweather.com/lastret.txt
Steve
I tried the latest update. The good news is that it did fix the excessive rain amounts. The bad news is that it broke the temperatures. It's now taking the Farenheit temperature and assuming it is Celsius, then converting it to Farenheit. So my 66 degrees becomes 151 degrees. You'll see it here: http://tylertexasweather.com/ttwfcast4.htm.
Check the $uoms in config.php, seems to be metric.
Henkka,
The $uoms looks correct to me.
#$uoms = array('C','mm','km/h','hPa','cm','km');
$uoms = array('F','in','mph','inHg','in','mi');
Steve
Hi Henkka,
Sorry late response, checked all Lat /Lon settings all correct.
I did some searching on the net and found those 2 scripts to be slightly flawed, also checked your site and TylerTexas (both showing incorrect Moon (Rise/Set) Times also.
Not sure what the answer is.
Also just noticed that UV is not utilized, would UV be difficult to add as it was in the 3in1.
Kind regards,
