Author Topic: Getting back to running a weather station  (Read 4018 times)
Offline administrator
  • Administrator
  • Blackpool, UK
  • Win NT 10.0
  • Chrome 55.0.2883.87
    • Weather-Watch.com
« on: February 10, 2017, 02:04:31 PM »
After too many years of not being able to run a station I'm starting to get to the point where it's feasible again. I've still got my (now aged) Davis station but parts of that are bolted to the roof and walls of another house and whilst I will get them down at some point it's not going to happen for a while. Assuming I can still find all the bits I suspect that the system will need a fair bit of maintenance too before it will work reliably.
So in the interim I'm getting a Bloomsky (Sky2 + Storm) station (please don't moan at me!). The intention being that I'll use this until I get the Davis back up and running and then move it to another location about a mile away as a second system. I've got the Sky2 module and I'm just waiting for the Storm module and tripod stand to be delivered.
So that's step 1 underway. Another change since my last station is that I no longer have a PC running 24*7 in the house. I tend to use my tablet/phone and only break out the PC or laptop when I need more oomph for whatever I'm doing...which seems to be about every couple of weeks at the moment. So I was wondering about putting a low power PC in just to effectively do 24*7 weather stuff, e.g. running WD and WxSIM. I'm way out of date on specs though. What kind of spec of PC would I need? I know you can get WD running on a Raspberry Pi, but that's a bit too minimal. If I wanted to run Win10, what spec of CPU, RAM, disk would I need? I'm thinking of something like a small mini-PC/cube device that sits in a corner using WiFi to do it's thing without a keyboard, mouse, monitor connected, so I'd do most of the work on it by RDP.
Any info, or even suggestions of suitable devices (available in the UK) would be very welcome.
Thanks in advance,
Chris
Chris
Weather Forum Administrator
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
  • Win 7/Srvr 2008R2
  • Chrome 56.0.2924.87
Re: Getting back to running a weather station
« Reply #1 on: February 10, 2017, 03:04:15 PM »
Can I laugh?
Seriously, this is all good news  :D
Bashy
  • Guest
« Reply #2 on: February 10, 2017, 03:20:40 PM »
Least its not a netamo.......  :lol:
I am running an old dual cor Pentium E2220 @ 2.4ghz with 4gb ram and a 300gb hdd
That is running 2 x wd + webcamcapture on 1 and wxsim and its working fine,
it also runs a macro every 30 mins to open note pad, copy the info and close it, then
opens Chrome and pastes the info.
That runs 24hrs with no problems at all, 4gb i feel is minimum nowadays if ya dont want
much lagging...
  • Administrator
  • Blackpool, UK
  • Win NT 10.0
    • Weather-Watch.com
« Reply #3 on: February 10, 2017, 03:23:17 PM »
Can I laugh?
I suspected you might do ;-) It remains to be seen how well it works when I get it installed. I'm impressed by the build quality of the Sky2 module, it's very sturdy and feels like a quality unit.
Chris
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #4 on: February 10, 2017, 03:43:06 PM »
Least its not a netatmo.......  :lol:
Amen to that  :lol:
I'm still using a low power/capability Atom D525 board with an Intel SSD to run WD and some scripts. If you aren't running anything heavy duty besides WD then any CPU with a rating higher than the D525's 701 on the Passmark list will do the job. Next it's a budget issue, at the high end Intel NUC or similar, at the low end no-name mini box from Asia.
  • Administrator
  • Blackpool, UK
  • Win NT 10.0
    • Weather-Watch.com
« Reply #5 on: February 10, 2017, 03:49:44 PM »
I've got a Netatmo too ;-) That's more to link in with the thermostat. It does seem to give realistic readings compared to other local stations, but I have seen some ridiculous values coming out of some. I suspect some are badly positioned and others may have the external temperature sensor indoors! So possibly not so much a problem with the devices and more about the users?
I guess that's a 'normal' sized PC? I'm hoping to find something smaller, low-ish power and therefore possibly no-fan and silent (so maybe SSD). Anyway you've provided one marker in the sand - dual-core 2.4GHz, 4GB RAM and 300GB HDD. How low can I go?!?!
Chris
  • Administrator
  • Blackpool, UK
  • Win NT 10.0
    • Weather-Watch.com
« Reply #6 on: February 10, 2017, 03:52:59 PM »
I've got a low-end mini box from Asia (running Linux) but they're really only intended to be used as TV media boxes. They're pretty locked down in terms of making changes to the OS and not even really patchable for security updates unless the supplier released an updated image. I suspect the Windows versions are much the same.
Chris
Bashy
  • Guest
« Reply #7 on: February 10, 2017, 04:08:08 PM »
Yeh it is, ido you not have a shed ya can set it up in then its out the way? just need a eco PSU and jobs a goodun :)
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #8 on: February 10, 2017, 04:15:36 PM »
I used to think the same but Devil demonstrated that it isn't so in this thread.
Offline broadstairs
  • Stuart
  • Broadstairs, Kent, UK
  • (Linux Mint)
  • Firefox 51.0
    • Broadstairs
« Reply #9 on: February 10, 2017, 05:13:47 PM »
I now run mine on a GigaByte Brix GB-BXBT-1900 currently using W7 but I am sure it runs W10 although from what I've read may need a BIOS update if not on the latest. It runs WD and WXSim and I do use it for the odd bit of net surfing. It also runs DSLStats to monitor my router. Sits silently in the corner not using a whole load of leccy! Not hugely expensive I think they are still about 100 +vat and of course you need memory and an SSD or HDD at that price, 2.5in drives fit inside no problem. Its about 4inches square and 2 inches high.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #10 on: February 10, 2017, 06:40:47 PM »
WD does support bloom sky as a weather station now
and WD will run OK on a low spec net pc (that is what I use ;) )
  • Administrator
  • Blackpool, UK
  • Win NT 10.0
    • Weather-Watch.com
« Reply #11 on: February 10, 2017, 07:40:37 PM »
Thanks for that. I'd seen those but dismissed them as only having a Celeron. I've not really tracked Celeron (too low spec for anything we'd use at work) so I didn't realise that the J1900 was 4 core.
Chris
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #12 on: February 10, 2017, 07:43:59 PM »
I feel Intel has really confused us old folks with their current use of the Celeron name  :lol:
  • Administrator
  • Blackpool, UK
  • Win NT 10.0
    • Weather-Watch.com
« Reply #13 on: February 10, 2017, 07:46:29 PM »
Yes, but there's no leccy in it, not even low power :-(
Chris
  • Administrator
  • Blackpool, UK
  • Win NT 10.0
    • Weather-Watch.com
« Reply #14 on: February 10, 2017, 07:48:41 PM »
Not helped by the fact that this old'un is spending far more of my time at work doing cyber-security rather than enterprise architecture.
Chris
