I was at home Envoy 8X, which can receive up to 8 ISS.
Can record the temperature at 0.1C from each temperature transmitter.
The problem is that the console uses an external temperature resolution of 0.5 and 0.6C, and thus these values are loaded round.
It’s in the software console and transferring Envoy of the console does not help.
I had to come back because this conga supported by WD.
I think Bashy is confusing the Envoy and Envoy8x - completely different beasts.
Logical, I didn’t know he had an 8x. My mistake.
I managed to get hold of a cheap envoy not x
I was told the other day on here that the envoy will do 0.0 opposed to the console only rounding it to 0
I also wanted the envoy so that I can move the console to where I want to in the house.
I want to know, if the iss cannot reach the console at the front of the house, cane the envoy retransmit to the console whilst still giving data to WD?
Not the regular, non-8x, Envoy, resolution depends on the sensor itself.
Yes.
OK thanks Niko, one more then, on my console, the soile is showing to 0.0 and 0, shows it I 2 sections, I posted a shot of it I’m the other day, yet wd only shows it to 0
Does it ever show other than 0 in the decimal? Internally the Davis works in F, so any temp displayed in C is converted.
Not quite 100% sure what ya mean, oh, hold on yes, i know what ya mean lol
Yes it does, say for example 1.2C, the non decimal figure will show, if its below 0.5 rounded to the lower
if its above 0.5 it will rounded up to the next, eg if the soil # is showing 1.3 in the other box it will show as 1
if its 1.8 it will show as 2
I was just about to take a photo and show you BUT, sods law its at 0.0C ha ha ha ha
7.2C is 45F, so I think it’s an F measured temp converted to C, and the display difference is just a display design choice.
Oki, I will keep an eye on it, but if for example if it says something like 0.1C that will not = a rounded F then
I will report back
Oh, there is one other thing, I am sure I read somewhere that the stainless steel temp was rounded to 0 but the one I have isn’t, may have made that up mind, will have look online in the morning :
Hi Niko, this morning the soil temp was 0.2C now if my mate google is correct then that is 32.36F
Hi folks, from what i gather, the Console is to the nearest 1C and both envoys to the nearest 0.1C or 1C,
but nothing said about the history and alarms for the 8x, thats the only difference i can find in the specs
Here’s the specs, i wrote it exact
The console (Outside temp/hum ISS)
Current data: 0.1
If you’ll allow me to dip in quickly:
Standard consoles and Envoys (not 8X which is a different animal altogether) behave identically. You must distinguish between temps from primary inside/outside sensors and supplementary (eg leaf/soil) sensors.
All in/out temps are processed by the console as 0.1F temps and converted to
Hi John, thanks for the info, using it for the external probe for inside temp could be a good option
for me as my weather pc is in the conservatory and the door is open all day long unless i have to
go out, so you can imagine what the indoor temps is like :lol:
I have also found out that the soil temp is reading at 0.0, thats what VPLive is telling me so i am baffled as to
why WD only grabs it at 0, unless the output data from the console is only producing it at 0, that will explain
that, question is John, whilst you are here, does the Envoy output the soil temp at 0.0?
Wait, that cant be right, the data is being sent as 0.0 because VPLive picked it up at that lol mm interesting…
What always needs to be remembered with Davis kit is that it’s US-designed and therefore all readings are held internally in US units, eg
Thats ok, half the time with stuff like this i need to be spoon fed as it can take a while or simplifying for it to sink in.
I think i get it, basically its in F and the console converts it, will have to ask Brian as to why WD will only do it to 0
thanks John and Niko
there is a custom tag to show vp soil temp to 1 dec place
(ie 0.5 c resolution)
