Author Topic: weatherproof rj11 joiner?  (Read 6228 times)
Bashy
  • Guest
« on: February 07, 2017, 03:13:28 PM »
Hi folks, im struggling to find some lower cost waterproof coupler  for the rj11s, what do you guys use please?
Offline looney2ns
  • Fearless Weather Dog-Loves to watch Lightning.
  • Near Evansville Indiana USA
  • Win 7/Srvr 2008R2
  • Chrome 55.0.2883.87
    • Newburgh Weather
Offline weatherc
  • Salo, Finland
  • Win NT 10.0
  • Firefox 47.0
    • Weatherstation Salo,FI
Re: weatherproof rj11 joiner?
« Reply #2 on: February 07, 2017, 04:11:50 PM »
No at all but instead Scotchlok's to extend the orginal cables. Been in use and out without additional coating in finnish weatherconditions for 8 years now with success for both my UV and solar-sensors.
http://solutions.3m.com/wps/portal/3M/en_US/EMDCI/Home/Products/ProductCatalog/~/3M-Scotchlok-IDC-Butt-Connector-UY?N=5430432+3294067407&rt=rud
Bashy
  • Guest
« Reply #3 on: February 07, 2017, 04:36:47 PM »
Cheers guys
With the scotchlocs, i would need 4 for each cable is that right?
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
  • Win 7/Srvr 2008R2
  • Chrome 56.0.2924.87
« Reply #4 on: February 07, 2017, 05:02:13 PM »
Yes.
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #5 on: February 07, 2017, 05:04:01 PM »
Be sure to check that wires in the final RJ11 are in the same order as in the original Davis RJ11. Phone cables can often be crossed and you don't want that.
Bashy
  • Guest
« Reply #6 on: February 07, 2017, 05:14:56 PM »
Cheers Niko, ha ha, funny ya say that, i bought 4 rj11 couplers, they were crossed
easy enough, 1 side was the same as the davis cable, so i just pulled the pins out of
the other side and refit them in the correct order, i learnt quickly that you only get a
max of 2 goes at bending the pins to get them out and refit them.  The only way i can
waterproof them is to hot glue then electrical tape, amalgamated tape would be better.
I was hoping to find something along the lines of the Davis version but cheaper, i need 3
Bashy
  • Guest
« Reply #7 on: February 07, 2017, 05:17:53 PM »
« Last Edit: February 07, 2017, 05:23:28 PM by Bashy »
Bashy
  • Guest
« Reply #8 on: February 07, 2017, 05:52:59 PM »
ok,  I think im gonna go for these its hard to tell how big and do i then just tape them to the mast?
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #9 on: February 07, 2017, 06:03:34 PM »
Phone wires seem to work on the "two wrongs make a right" principle, crossover in the cable cancelled out by another crossover in the connector  :lol:
Bashy
  • Guest
« Reply #10 on: February 07, 2017, 06:26:11 PM »
Yeah, i had already made up the cables though before the couplers arrived  :roll:
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #11 on: February 07, 2017, 06:36:30 PM »
Those scotchloks are quite small, they only need protecting from direct driving rain, so yes, tape to mast will work. For a bit of extra protection I would make a drip loop - u-turn the wire from the sensor back up the mast for a few inches so that the connectors are pointing up when you tape them.
Bashy
  • Guest
« Reply #12 on: February 07, 2017, 06:38:35 PM »
Brill, sounds like a plan to me, thanks, only another 8 days for the mast to arrive :/
Offline weatherc
  • Salo, Finland
  • Win NT 10.0
  • Firefox 47.0
« Reply #13 on: February 07, 2017, 07:55:32 PM »
Yep, thats the way i have done it too. Of course a layer of tape around the whole thing would give even more protection but the tape-packet would need to be 110% water/moist-proof then wich is in de facto impossible when 2 wires goes inside it. The experience from my own fiddlings togethter with our wet/humid/frozen fall/winter where humidity stays at around 100% for months are that no protection at all are better than bad protection.
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #14 on: February 07, 2017, 08:35:19 PM »
Well, if you really want it weatherproof :wink:  Get a short length of plastic tube (e.g. pvc conduit), cap one end, fill it half way (or more) with hi-temp silicone electrical (dielectric) grease. Mount it open end down on the mast, u-turn the spliced wires up into the tube so that the spices and ends of the cable jackets are well in the grease. Tape/clip the wires to the mast, stuff the open end of the tube with rubber/plastic foam to keep it clean.
