Author Topic: Upgraded Davis fan and mast mount  (Read 1101 times)
Bashy
  • Guest
« on: February 04, 2017, 02:32:38 PM »
I decided to upgrade the Davis fan to a 12v, it's so much easier to find a 12v psu :)
Also managed to make a mast mount for the uv and solar it's just two small shelf brackets with a bit of foam, I will the use jubilee clips in the mast.
Also fully separated the temp shield and used another larger shelf bracket and a strip of metal.  It's all set up temporary for jobs with but not the wind
