Hi Brian, please see https://www.wunderground.com/personal-weather-station/dashboard?ID=IWEETING2#history
Wind gust is not right, even no wind speed, gust still at 29mph
use this new WDrapidfire update to fix that
http://www.weather-display.com/downloadfiles/WDrapidfire.zip
:oops: #-o
Thanks Brian, thats got it
the new WDrapidfire version is to be able to use https when that becomes the only way to update WU
but I had missed 1 line of code
Ah, no worries, it was only since that last update anyway
i am having the same issue…i updated WD on 12/15/16 to 10.37S35…i thought it had fixed it…never checked…but i checked today and i am having the same issue…
https://www.wunderground.com/personal-weather-station/dashboard?ID=KRIBRIST15
Starting 12/5/16 is when it seemed to start happening…its slowly climbed and has stayed at 38.0 mph since…even when i updated to the version that is to fix this issue…
Are you positive you are using the latest version?
testtags.php shows B35
$wdversion = '10.37S' . '-(b' . '35' . ')'; // Weather Display version number you are running
$wdversiononly = '10.37S';
$wdbuild = '35'; // Weather Display build number you are running
yes i am…can send a picture… if you go to http://www.rudmanradar.com/ …scroll to the bottom, you can see i am…
Build 36 is the latest.
i thought i was…i am on Build 35 but thought Build 33 fixed this issue?
just an update, i am running the latest version on WD… and it seems to still be producing the problem…what should rapid fire settings be?
i think i may have figured out my issue…after playing around with some settings…it looks like my rapid fire settings “gust since last send” was checked…i unchecked it and it seems to be working…why i never had a problem before is beyond me…
WU graph starts to look good
i have that setting ticked and it works OK for me
https://www.wunderground.com/personal-weather-station/dashboard?ID=IFRANKLI1
interesting…i wonder why its all of a sudden a problem? seems WU is the only service that is an issue with at least my station?
This has fixed the problem that I reported here Uploading Wunderground Wind Data
The only other way I found to fix my problem was to revert back to Weather Display v10.37S-29, which used the old rapid fire uploader.
I appreciate you finding this fix!
i have that setting set …with no problem
do you also have set to swap gust/av?
Currently I have “swap gust/av” checked and have unchecked “gust since last send” with better results than with “gust since last send” checked.
Should I try a different combination?
try as a test swapping that situation?
