All done Mick, up and running, i tested the tipping on a spare console and it worked great, thank you ever so much,
didnt realise it would be so simple, even sorted out the heating side of it, i think i will need to get either a PC PSU
or a PSU normally used for CB radio, I am using the same power as the temp shield seen as its right near the rain gauge
Problem is, even with just one fan running in the temp shield i cannot have any more than a 5w bulb in the bucket,
well, i can use a 16w if i go direct, but if i go higher using the thermostat board,the relay just clicks, so i presume it cannot
draw enough power, cross that bridge later on, at least for now, the bucket is working, tip adjusted in WD so ready for
a live test now, you can bet ya last quid it wont rain for ages now :roll:
Niko, can you confirm please the info in the image sounds about right?
