Author Topic: Davis bucket to OS  (Read 5856 times)
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
  • Win 7/Srvr 2008R2
  • Chrome 55.0.2883.87
Re: Davis bucket to OS
« Reply #30 on: December 17, 2016, 03:28:34 PM »
Niko, can you confirm please the info in the image sounds about right?
It would be if you were sticking a 165 mm funnel on a 100 mm gauge and wanted to know the new tip size, but I fear 100 mm is the OS funnel diameter and 165 mm is the Davis funnel diameter so I'm confused :dontknow:
Are you trying to figure out the Davis tip size? It will be 0.01 inch, 0.254 mm, unless you change the funnel size.
Offline MichaelPT
  • Staffordshire Nr Leek
  • Win NT 10.0
  • Chrome 54.0.2840.99
    • Weather-Above
« Reply #31 on: December 17, 2016, 04:08:30 PM »
All done Mick, up and running, i tested the tipping on a spare console and it worked great, thank you ever so much,
didnt realise it would be so simple, even sorted out the heating side of it, i think i will need to get either a PC PSU
or a PSU normally used for CB radio, I am using the same power as the temp shield seen as its right near the rain gauge
Problem is, even with just one fan running in the temp shield i cannot have any more than a 5w bulb in the bucket,
well, i can use a 16w if i go direct, but if i go higher using the thermostat board,the relay just clicks, so i presume it cannot
draw enough power, cross that bridge later on, at least for now, the bucket is working, tip adjusted in WD so ready for
a live test now, you can bet ya last quid it wont rain for ages now  :roll:
That's really good news I told you it was simple sometimes we can overcomplicate things
You'll notice in the posts of the people suggested exactly the same things I've illustrated
sometimes an image can speak a thousand words
Do you need help with your rain gauge heater?
mick
Bashy
  • Guest
« Reply #32 on: December 17, 2016, 04:42:48 PM »
Hi Niko, see, my brain hates math, I confuse myself over nothing :/  I was thinking cause the original bucket was 100mm I needed to account for that  #-o so for now I just add 0.254 to WD tip offset? It's prob only for tonight, I may add the bigger funnel tomorrow, will have to see how it goes.
Hi Mick, you should know me by now and over thinking things, see my reply to Niko for starters lol
The only issue I have with the heater is that the relay clicks
And does not light the 16w bulb, it was OK earlier with a 5w but I just checked it again and it just clicks, I think that because I am using the feed from the temp shield fans that there is too much drain for the small 12v psu for the relay to use.  Does that make sense?  If I by pass the relay the bulbs light up, both 5w and 16w, gonna have another look tomorrow and use a separate psu and see how that goes.
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #33 on: December 17, 2016, 04:50:26 PM »
WD is set for a WMR928/968 - right? What tip size does WD default to for that, 1mm ?
Bashy
  • Guest
« Reply #34 on: December 17, 2016, 05:24:53 PM »
yes, that's right, 1mm for the OS bucket
Bashy
  • Guest
« Reply #35 on: December 17, 2016, 05:25:55 PM »
This is what I ended up with
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #36 on: December 17, 2016, 05:39:07 PM »
OK put 0.254 in the "Modified rain gauge new tip (mm)" box on the Rain Offset page, and the Rainfall offset % should be 0.
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #37 on: December 17, 2016, 05:41:29 PM »
Is that circuit board coated? If not you may want to put a baggie on it to protect it from any splashing.
Bashy
  • Guest
« Reply #38 on: December 17, 2016, 05:49:40 PM »
Thanks Niko, i get it now, i was thinking that the OS board was part of the calc but i take it the OS board
basically is just for very short term storing and transmitting.
The board is out of the OS bucket so i would say its sealed but i still need to add a drop of hot glue to the
old reed switch connectors, that i can do tomorrow or when i do the new funnel, i need the glue for that so
2 birds an all that.... thanks again for you brains :)
Offline MichaelPT
  • Win NT 10.0
    • Weather-Above
« Reply #39 on: December 17, 2016, 06:05:29 PM »
Good see it working
I've updated the webpage to link to my home-made rain gauge into, and updated the page with a link to the conversion
for anybody else you may want to use the info
http://www.weather-above.com/STATION%20INFO%202.html
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #40 on: December 17, 2016, 06:09:39 PM »
Thanks for your expert help Mick  :)
Bashy
  • Guest
« Reply #41 on: December 17, 2016, 06:25:46 PM »
Thanks again Mick, really appreciate it, you too Niko :)
Bashy
  • Guest
« Reply #42 on: December 18, 2016, 10:53:26 AM »
Well, chuffed with this, now added the funnel and its operating at 0.1mm
I have also checked calibration using syringe and its spot on at 4.9ml :)
I have also added a separate pouch for the heater now and that works fine for the 12v 5w bulb
but it looks like I need at least a 12v 1 to 2amp psu to run the 16w bulb  thanks guys...
Finnished product
Offline looney2ns
  • Fearless Weather Dog-Loves to watch Lightning.
  • Near Evansville Indiana USA
  • Win 7/Srvr 2008R2
    • Newburgh Weather
« Reply #43 on: December 20, 2016, 10:23:36 PM »
Nice job Bashy!
