do you mean you have WD set to client mode and set to use this clientraw.txt file as a data source?
if so, have you set to use the solar data in the client/server setup?
if so, the solar data needs to be in data position 127
so you would need to add in more NULL (e.g 0) then that data
no , i said NULL is e.g 0
you need to fill in the missing data that needs to come before where WD expects the solar data to be (i.e data positoin 127) with 0’s (and or where it expects text, eg —)
One thing is that you have a space in “Whimick Met” which will upset the position count (it is a space delimited file). Also that field usually includes the time “ShastaCo-12:30:44” but I’m not sure if that will make a difference.
@Whimick: I suggest grabbing a copy of someone’s real WD clientraw file, verify that it drives WD, and then test what you are doing by substituting data into the file.
Am I right in thinking that the solar data is being picked up by WD but has a value 10 times smaller than the data in the clientraw file it should be 593 not 59.3, is this correct, if not how do I correct it?
And why is it not being shown as a current % reading, or plotted on WD?
