Good point Brian, it’s a very misleading presentation due to the parallax.
Serge: Essayez d’utiliser un affichage bidimensionnel, pas trois dimensions.
Je vais essay
Apr
That works
good to see people making the use of the very powerful customisation
Oui cela est bien.
Serge
How is the wifi connection to the depth sensor working?
Comment fonctionne la connexion Wi-Fi au capteur de profondeur?
Merci
MikeyM
Bonjour MikeyM,
Je suis d
Merci Serge
:x-mas: :reindeer:
Happy Holidays!
MikeyM
Bonjour “mikeym”
As-tu install
Bonjour,
Je suis tellement satisfait par ce system, je d
Hi Serge
No I haven’t installed a WiFi adapter yet. Glad yours is working so well. What model are you using again? And what is the link to your snow sensor? I had very good luck with the LR4/414D combination last Winter, but I did have to add a simple heater to the enclosure.
MikeyM
Salut Serge
Non, je n’ai pas encore install
Bonjour “mikeym”,
J
Bonjour,
a second probe to measure snow depth you mean?
He wants something to monitor a creek/stream. I assume that means water level but using the same ultrasonic sensor with RS-232 comm.
“He wants something to monitor a creek/stream. I assume that means water level but using the same ultrasonic sensor with RS-232 com”
Yes
Une nouvelle demande pour savoir si cela est possible ?
Merci
