what shows under view, debug info, after you click on connect
Peut-
Please tell us which Maxbotix you have:
MB7334 or MB7354 or MB7364
I see you must have set to log the raw data
under setup, advanced/misc
untick that
so as to not confuse things
Bonjour Niko,
Capteur MB7354
Merci Niko,
Je vais contr
Non
try a new .zip update of WD re the raw data showing under view, debug info, in WD
Brian,
J’ai install
[quote author=eongibier link=topic=63751.msg512259#msg512259 date=1478683532]
Non
have you clicked on connect (and set the needed com port number) in setup, misc…snow depth tab, Maxbotix setup?
Merci Niko.
Yes Brian.
[quote author=niko link=topic=63751.msg512271#msg512271 date=1478709021]
FTDI should be OK.
If you have a multim
Bonjour Serge
Did you test with the programme du terminal ?
Non Niko avec le : “the voltage on the MB pin 3”
OK, merci, so it’s clear for Brian:
Serge has tested the sensor’s analog output and it is working normally.
the screen shot of the settings in WD shows a different com port that the test software screen shot though
