Software native RS-232
Hello,
(Sorry for my English, it is a translator)
Looking for a software native RS-232 can create graphics.
Thank you
Can you try that en fran
Ok,
Je cherche un logiciel afin de faire fonctionner un capteur de hauteur de neige en RS-232 natif.
Merci
Serge
Merci :slight_smile:
Serge is looking for software for a snow depth sensor which has an RS-232 output, and it should generate graphs/charts.
@Serge: Please tell us the make and model of the sensor (marque et le mod
Bonjour,
Voici le capteur que je veux utiliser :
http://www.maxbotix.com/SelectionGuide/outdoor-snow.htm#snow
Je ne veux pas passer par Hobby Board qui n’existe plus, je d
I see that the Maxbotix ultrasonic sensors are available with RS232 output. You can find many programs for collecting and storing RS232 data, for example from Windmill. But if you use a program to collect the data from the sensor I don’t know any way to pass that data into WD. I think you will have to ask Brian to add this facility to WD directly.
Bonjour,
Merci, je vais demander
I have added initial support to get the raw data (I sent you a PM)
Bonsoir Brian,
Je n’ai rien comme relev
what shows under view, debug info, after you click on connect
J’ai contr
Peut-
Please tell us which Maxbotix you have:
MB7334 or MB7354 or MB7364
I see you must have set to log the raw data
under setup, advanced/misc
untick that
so as to not confuse things
Bonjour Niko,
Capteur MB7354
Merci Niko,
Je vais contr
Non
try a new .zip update of WD re the raw data showing under view, debug info, in WD
Brian,
J’ai install
