Author Topic: Software native RS-232  (Read 21817 times)
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
  • Win 7/Srvr 2008R2
  • Chrome 54.0.2840.71
Re: Software native RS-232
« Reply #15 on: November 08, 2016, 05:09:05 PM »
Offline eongibier
  • Vaisala 520 - Détecteur de hauteur de neige
  • Château-des-Prés (France Haut-Jura)
  • Win NT 6.3
  • Mozilla compatible
« Reply #16 on: November 08, 2016, 06:05:02 PM »
Merci Niko,
Je vais contrôler ça demain.
Serge
Offline eongibier
  • Win NT 6.3
« Reply #17 on: November 09, 2016, 09:25:32 AM »
Non ça fonctionne pas, j'ai bien suivi ton shéma  Niko.
J'utilise un USB Serial Converter de chez FTDI cela peut-il empêcher le bon fonctionnement ?
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #18 on: November 09, 2016, 09:39:42 AM »
try a new .zip update of WD re the raw data showing under view, debug info, in WD
Offline eongibier
  • Win NT 6.3
« Reply #19 on: November 09, 2016, 01:30:51 PM »
Brian,
J'ai installé la mise à jour, pour l'instant rien.
Brian,
I installed the update, for now nothing.
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #20 on: November 09, 2016, 04:30:21 PM »
FTDI should be OK.
If you have a multimètre check the voltage on the MB pin 3, the voltage corresponds to the distance measurement and will tell you if the MB is working.
Quote
Pin 3- Analog Voltage Output: This pin outputs a single ended analog voltage scaled representation of the distance.
This output is referenced to the sensor ground and Vcc. After the ~50mS power up initialization, the voltage on this pin
is set to a low voltage. Once the sensor has completed a range reading the voltage on this pin is set to the voltage
corresponding to the latest measured distance.
Also I would use a programme du terminal like Realterm to test the MB independent of WD. In Realterm set Display to ASCII, and Port to the port number you are using, 9600 baud, 8 data bits, no parity, with one stop bit.
I'm sure Brian will get this working, but it would be good to be sure you have a good MB.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #21 on: November 09, 2016, 05:05:16 PM »
have you clicked on connect (and set the needed com port number) in setup, misc...snow depth tab, Maxbotix setup?
Offline eongibier
  • Win NT 6.3
« Reply #22 on: November 09, 2016, 05:07:18 PM »
Merci Niko.
Offline eongibier
  • Win NT 6.3
« Reply #23 on: November 11, 2016, 04:26:41 PM »
Yes Brian.
Offline eongibier
  • Win NT 6.3
« Reply #24 on: November 14, 2016, 09:12:27 AM »
FTDI should be OK.
Bonjour Niko,
J'ai bien suivi tes informations ; le capteur réagit lors d'un branchement avec un appareil de mesure.
Maintenant reste à savoir pourquoi ça ne fonctionne pas avec WD ?
Serge
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #25 on: November 14, 2016, 02:50:14 PM »
Bonjour Serge
Did you test with the programme du terminal ?
Offline eongibier
  • Win NT 6.3
« Reply #26 on: November 14, 2016, 04:36:22 PM »
Non Niko avec le : "the voltage on the MB pin 3"
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #27 on: November 14, 2016, 04:51:46 PM »
OK, merci, so it's clear for Brian:
Serge has tested the sensor's analog output and it is working normally.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #28 on: November 14, 2016, 06:12:15 PM »
the screen shot of the settings in WD shows a different com port that the test software screen shot though
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #29 on: November 14, 2016, 06:33:41 PM »
In the terminal program screenshot? That's just a port that's on my laptop, Serge didn't test with a terminal program, he only tested the analog output. According to the maxbotix doc it should just default to sending serial data, but it would have been nice to test that independent of WD.
