Author Topic: Software native RS-232  (Read 18854 times)
Offline eongibier
  • Vaisala 520 - Détecteur de hauteur de neige
  • Château-des-Prés (France Haut-Jura)
  • Win NT 6.3
  • Mozilla compatible
« on: October 18, 2016, 04:24:00 PM »
Hello,
(Sorry for my English, it is a translator)
Looking for a software native RS-232 can create graphics.
Thank you
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
  • Win 7/Srvr 2008R2
  • Chrome 53.0.2785.143
Re: Software native RS-232
« Reply #1 on: October 18, 2016, 06:31:13 PM »
Can you try that en français, s’il vous plaît?
Offline eongibier
  • Win NT 6.3
« Reply #2 on: October 19, 2016, 04:05:25 AM »
Ok,
Je cherche un logiciel afin de faire fonctionner un capteur de hauteur de neige en RS-232 natif.
Merci
Serge
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #3 on: October 19, 2016, 01:54:49 PM »
Merci  :)
Serge is looking for software for a snow depth sensor which has an RS-232 output, and it should generate graphs/charts.
@Serge: Please tell us the make and model of the sensor (marque et le modèle du capteur), it is possible someone is already using the same one.
If you are going to put the graphs on your website, you only need the software to generate a data file. Then you can use jpgraph or highcharts to create the graphs on the website.
Offline eongibier
  • Win NT 6.3
« Reply #4 on: October 20, 2016, 05:59:15 PM »
Bonjour,
Voici le capteur que je veux utiliser :
http://www.maxbotix.com/SelectionGuide/outdoor-snow.htm#snow
Je ne veux pas passer par Hobby Board qui n'existe plus, je désire une entrée en RS-232 par WD.
Merci.
Serge
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #5 on: October 20, 2016, 10:36:37 PM »
I see that the Maxbotix ultrasonic sensors are available with RS232 output. You can find many programs for collecting and storing RS232 data, for example from  Windmill. But if you use a program to collect the data from the sensor I don't know any way to pass that data into WD. I think you will have to ask Brian to add this facility to WD directly.
Offline eongibier
  • Win NT 6.3
« Reply #6 on: October 21, 2016, 09:36:14 AM »
Bonjour,
Merci, je vais demander à Brian.
Serge
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 54.0.2840.71
    • Weather Display
« Reply #7 on: November 03, 2016, 07:11:11 PM »
I have added initial support to get the raw data (I sent you a PM)
Offline eongibier
  • Win NT 6.3
« Reply #8 on: November 06, 2016, 05:46:44 PM »
Bonsoir Brian,
Je n'ai rien comme relevé, voici ma configuration.
Brian Good evening,
I did not like reading, here is my configuration.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #9 on: November 06, 2016, 06:26:10 PM »
what shows under view, debug info, after you click on connect
Offline eongibier
  • Win NT 6.3
« Reply #10 on: November 07, 2016, 10:09:52 AM »
J'ai contrôlé, j'ai rien...
I checked, I have nothing ...
Offline eongibier
  • Win NT 6.3
« Reply #11 on: November 07, 2016, 12:14:02 PM »
Peut-être qu'il s'agit de mon branchement ?
Parmi les spécialistes, pouvez-vous m'expliquer comment relier par un petit schéma car je ne comprends pas vraiment le branchement .
Merci
Maybe it is my connection?
Among specialists, can you explain how to connect a small scheme because I do not really understand the connection.
"Maxbotix"
http://www.maxbotix.com/documents/HRXL-MaxSonar-WRS_Datasheet.pdf
We recommend powering that the sensor is powered at 5VDC when connecting the sensor to a computer's DB9 connection. It is also recommended that the power supplied to the sensor is from a voltage regulator or any source able to provide clean stable power to the sensor.
To interface the sensor with the computer, pin 5 on the DB9 connection must be connected to the GND pin on the MaxSonar® and pin 2 on the DB9 connection must be connected to Pin 5 (TX) on the MaxSonar®. Please refer to figure 1.1 below for the pin layout of DB9 serial connections.
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #12 on: November 07, 2016, 04:46:03 PM »
Please tell us which Maxbotix you have:
MB7334 or MB7354 or MB7364
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #13 on: November 07, 2016, 05:43:13 PM »
I see you must have set to log the raw data
under setup, advanced/misc
untick that
so as to not confuse things
Offline eongibier
  • Win NT 6.3
« Reply #14 on: November 08, 2016, 03:21:16 PM »
Bonjour Niko,
Capteur MB7354
