Has anyone actually used these to create a clock in the header?
If so, can you point me to the correct documents/samples
You will have to use the full SteelSeries library as the version supplied with the gauges is cut down and does not include the clock component.
There is a demo page that shows the clock component in use.
2.8 releases since april work with the full Steelseries, including the clock scripts and are adapted to use that version.
There was a interim-release announced at: Leuven-Template 2.8 version available
One of the2.8 Canadian users with a clock in the header is http://www.sanfordweather.com/weather2/index.php
A Dutch user is: http://www.meteosauwerd.nl/weather/index.php
Some 2.7 sites are also using them.
Hope this helps, but i am still a bit puzzled as why you want this as you are a Meteotemplate user now.
Info filed away - thanks Wim.
