I have updated to latest release, rebooted PC and still can’t send a report email. But a simple test email via Thunderbird goes through just fine.
Server is 1and1.com, and I have port 587 for ssl, as well as account id & pw set up as it has been for years.
Any suggestions?
Log follows:
Connecting to mail server.
Attempting to connect to server.
OK
Socket connection established.
Starting secure channel handshake.
Sending 186 bytes of handshake data.
Receiving 58 bytes of handshake data.
error during handshake[2]: 0x80090308
Failed to connect: error during handshake[2]: 0x80090308
OK
OK
Disconnected. actual messages from upload session* Start Time/date:9:59:38 PM 7/24/2016
mez014.txt
Permanent connection selected
Checking for what else to do…
there are 1 more things to do
Sending Weather Report Email, auth
OK
OK
OK
Disconnected.
ERROR: 276: error during handshake[2]: 0x80090308 at time/date 9:59:39 PM
7/24/2016 agenda item: doreport
I have updated to latest release, rebooted PC and still can't send a report email
its not very clear if that means it was not working, and so you updated WD
or it was working , but not now, after updating WD
or your email provider, 1&1 , now require secure email server to be in use
does the weather warning email work in WD? (test that)
Reason for update was to see if t Weather reports had been going just fine until Friday morning when suddenly the morning report came through with only headers, and no text; Thursday evening’s report had been just fine. So after some investigation and seeing the error mesages in the log I thought there might be a new security issue I had missed. That caused me to update to release 15 on Saturday. Tonight after no improvement Saturday or today, Sunday, I noticed a new update claiming an FTP fix so pulled that hoping and here we are; still no weather report.
1and1 (home is 1and1.de) has required port 587 and startTLS for years now. No change there.
Something changed somewhere and I do not think it was WD; just thought someone might have an idea I could try.
it sounds like 1&1 has changed things re the sending email (i.e the type of security)
the changes to the FTP program are to enable support for secure FTP, which 1&1 are changing to
there has been no changes to the weather report email send
if you could email me your email settings and I will see if I can get it working
this thread is about the weather report email not being sent though, after a change by 1&1
(ie not related directly to the recent changes in the secure FTP)
I notice that using your settings, and the oringal ftpupd.exe version to send the email, it fails too…
so if it used to work, then it means its some change that 1&1 have made
Changing to port 25 didn’t do it. Got following log:
list of files uploaded**
[10060] Connection timed out
Failed to connect: [10060] Connection timed out actual messages from upload session* Start Time/date:12:11:36 PM 7/25/2016
mez014.txt
ERROR: 10060: [10060] Connection timed out at time/date 12:11:58 PM 7/25/2016
All as you suggest, with sme result so to be sure I cleared the log, restarted WD
use auth and ssl checked, port 25 and here is result :
mez014.txt
double check the mail server settings again in WD…I could add to the logfile what the mail server its trying to connect to…the error you are getting suggests either you have misconfigured the mail server or your firewall is blocking things or similar
I updated to the current version yesterday also and my email weather report has stopped working I’m running win 10 using goddady and have changed nothing else but to update. I can send email using my email program with the same settings.??
OK
Sending 196 bytes of handshake data.
Receiving 64 bytes of handshake data.
OK
OK
Disconnected.
OK
Connected.
220 p3plsmtpa11-06.prod.phx3.secureserver.net ESMTP
EHLO BeachServer1 250-p3plsmtpa11-06.prod.phx3.secureserver.net hello [24.181.xxx.xxx], secureserver.net
250-HELP
250-AUTH LOGIN PLAIN
250-SIZE 31457280
250-PIPELINING
250-8BITMIME
250 OK
STARTTLS
500 command unrecognized actual messages from upload session* Start Time/date:1:38:01 PM 7/25/2016
waz021.txt
OK
Connected.
250-HELP
250-SIZE 31457280
250-PIPELINING
250-8BITMIME
250 OK
STARTTLS
ERROR: 161: SMTP protocol error. 500 command unrecognized. at time/date 1:38:03
PM 7/25/2016 agenda item: doreport2
