Thanks Brian, using the following worked.
Brian the gradient temperature and color theme looks great. http://southwestweather.com/pws/KAZYOUNG2.php?theme=color
Thanks again
BTrip
Brian,
Really like the temperature gradients. Are you able to do it for the light theme as well? Think it would look good on that one too.
Paul
Yes i second that , it would be a nice addition. As Brian said though turbulent times in Turkey. Be safe Brian.
Steve.
Hi unfortunately it will have to wait till the weekend my internet is only in range when near land currently and at best 2g speeds so nigh on impossible to add any changes or upload but I will add on the gradients to light theme when I get home and fix the below zero not reflecting gradient output Blainec…
Brian
Thank you.
I can wait until you return from vacation
updated download or you can use simple fix attached
1.fix below zero gradient now also includes gradient temperatures for light theme
2.just update the three css files in the zip attached
3.replace existing temperature.php with one in zip attached
brian
gradientfix.zip (48.1 KB)
Brian,
Thanks so much for doing this, especially as it sounds like you are away. The temperature trend chevron is showing up as blue, so doesn’t stand out very much. It’s the code from line 120 to 130 in temperature.php
I overwrote the new code with the code from the previous temperature.php and temp trend chevron is now back to being white.
Thanks again.
Paul
Good evening
all 3 themes now include gradient temperatures
Fixes (21 APRIL 2017)
- Adressed all minor isuues with with temperature.php gradients and solar.php color issues . css files updated, temperature.php and all solar(1 and 2).php updated
Fix /Update/gradient (19 APRIL 2017)
- Fix below zero gradient output, added gradient temperature colors to light theme.fixed Portuguese flag option in common.php
https://www.weather34.com/homeweatherstation/index.html
brian
The update today made the Forecast Summary icons small again for IE 11.
good morning
IE11 what a suprise ok i have completely re wrote the script for the outlook.php please find attached and if you can let me know you can check the demo prior to using it
at http://boutiquehotelitaly.com/devpws/ just click the forecast summary .
basically simplified the whole script
<?php // 23 april 2017 new summary outlook using WU for weather34 homeweatherstation template // $weather34wuurl = file_get_contents("../jsondata/wuweatherupdate.txt"); $parsed_weather34wujson = (json_decode($weather34wuurl)); $forecastday = $parsed_weather34wujson->{'forecast'}->{'txt_forecast'}->{'forecastday'}; $count = count($forecastday); for($i = 0; $i < $count; $i++) { $period = $forecastday[$i]; if($period->{'period'} == 1 || $period->{'period'} == 3 || $period->{'period'} == 2) { $icon=$parsed_weather34wujson->{'forecast'}->{'txt_forecast'}->{'forecastday'}[$i]->{'icon'}; $forecast = $parsed_weather34wujson->{'forecast'}->{'txt_forecast'}->{'forecastday'}[$i]->{'fcttext'}; $forecastm = $parsed_weather34wujson->{'forecast'}->{'txt_forecast'}->{'forecastday'}[$i]->{'fcttext_metric'}; $rain = $parsed_weather34wujson->{'forecast'}->{'txt_forecast'}->{'forecastday'}[$i]->{'pop'}; $dayofweek = $period->{'title'}; echo "" ; echo ""; echo "" ; echo $dayofweek; echo " " ; echo "" ; if ($tempunit=='C')echo $forecastm; else echo $forecast; echo " ";}} //end summary outlook using WU for weather34 homeweatherstation template ?>
looks like it ok just managed to get my IE laptop working
IE11 Fix(23 APRIL 2017)
- outlook.php fixed not rendering SVG icons correctly in IE11 re-wrote script from scratch only need to update outlook.php in the forecast folder.
Fix/Update Forecast (22 APRIL 2017)
- All forecast scripts using SVG icons. Fixed minor earthquake css error.
if you just want the outlook.php zip you can just use the one attached .
place this in the forecast folder replacing existing. it has been verified ok for IE11
outlook.php.zip (1.76 KB)
Thanks Brian, it’s working fine in IE 11.
Brian,
Awhile ago I was having a problem with the main page loading completely. I have fixed that and created another problem. My WU forecast is not updating. Could you point me in the right direction. I have checked and the WU station and api key are correct.
Bill
Frontrangeweather.net/PWS/ index.php
win 7 home prem
weather display ver 1037s b 45
Hi Gentlemen.
i have just done a clean install of latest build 3.4gm, working ok exept wu graphs dont show?? WU station and api is there. Any ide whats wrong Brian?
I have stopped the cron jobs from my old version.
drop me a pm or email see if we can resolve it…brian
Version 3.4WF REQUIRES FULL Update(25 APRIL 2017)
https://weather34.com/homeweatherstation/
Version 3.4WF important to do full update many files updated .you may retain your settings1.php
Additional preparation for upcoming WEATHERFLOW hardware. version id moved to Version 3.4WF
Improved meteobridge-direct barometer trend output
outlook.php cleaned up code now works in your chosen preferred language set up in easyweathersetup.php
True timestamps for data last updated
All css files updated includes performance,changes to reflect timestamp,solar data and new additional code for upcoming optional module feature
solar1.php / solar2.php now reflect it is a UVINDEX forecast not a realtime measurement.
static demo http://boutiquehotelitaly.com/devpws/
Brian,
What is the upcoming optional module feature?
I am intrigued…also wondered whether you have found a simple MySQL solution?
Thanks again for helping me at the weekend.
Paul
