Author Topic: 'Idesign Simplicity' Template by Brian Underdown  (Read 119038 times)
Offline Tlowe
  • Minneapolis, MN, US
  • Win 7/Srvr 2008R2
  • Chrome 66.0.3359.181
Re: 'Idesign Simplicity' Template by Brian Underdown
« Reply #825 on: May 25, 2018, 01:42:11 PM »
Hmmmm.....I wonder what happens with existing API keys. Don't see any info on that. It would seem that if you provide them with data they should give you a free key. Maybe they will make a consideration for non commercial use.
Offline Tlowe
  • Win 7/Srvr 2008R2
« Reply #826 on: May 25, 2018, 01:55:59 PM »
Here is a forum discussion at weather underground about the change.
https://apicommunity.wunderground.com/weatherapi/topics/weather-underground-api-changes
Offline bitsostring
  • Oregon Scientific WMR200
  • Edinburgh, U.K.
  • Win NT 10.0
  • Mozilla compatible
    • Home Weather Station
« Reply #827 on: May 25, 2018, 03:39:00 PM »
Thanks. I see that "for the time being, free keys will continue to work.  We will update you if that changes."
Presume that promise to update refers to the forum, not to individuals. . .
It's meant to be fun. . .
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 66.0.3359.139
    • Weather Display
« Reply #828 on: May 26, 2018, 10:15:14 PM »
you would need to also stop your CWOP updates too (as WU can get your data from that source )
Offline Tlowe
  • Win NT 10.0
  • Chrome 73.0.3683.86
« Reply #829 on: April 02, 2019, 06:53:50 PM »
Has anyone tried the new API Keys from Weather Underground. I logged in and was able to generate a new key. It is not working so far, but as I remember it took awhile for it to work when I generated the old key.
« Last Edit: April 02, 2019, 07:20:24 PM by Tlowe »
Offline bitsostring
  • Edinburgh, U.K.
  • Win NT 10.0
  • Chrome 64.0.3282.140
« Reply #830 on: April 02, 2019, 07:21:37 PM »
Regret the new key is never going to work with the old w34 version you have. You need to look here for the latest version, which does not get a forecast from WU either. However, there will soon be a new release that does give the option of a forecast from WU.
Online wvdkuil
  • Wim van der Kuil
  • Leuven Belgium CET
  • Mac OS X 10.13.6
  • Chrome 72.0.3626.119
    • My PWS at Leuven Belgium Europe
« Reply #831 on: April 02, 2019, 07:38:44 PM »
The normal release is ready but the documentation needs improvements and there is a lot more work with updating the language files then I expected.
But if you want to switch to the latest version, including the the WeatherUnderground 5 day forecast, download the March 31, beta version and test.
No need to call it "beta" anymore.   All functions should work OK.
Download available at http://wd34.weather-template.com/beta.php
The "old" documentation can be found at http://wd34.weather-template.com/
Also when using WeatherUnderground, there is no need to start using the SQL-table.
The pop-up graphs work OK with the WU-data.  nothing has changed there.
Support & demo PWS_Dasboard  (HWS_template) http://pwsdashboard.weather-template.com/
My PWS at home https://weer.sluispark.be/
And at my daughters house https://www.weerstation-herent.be/
Offline Tlowe
  • Win NT 10.0
« Reply #832 on: April 02, 2019, 07:52:21 PM »
Thanks, I was unaware of the new versions did someone take this project over from Brian Underwood?
Ahhhh, I see the other thread now.
