I have noticed that the Dallas 1 wire reader stops working after a short period of time. When I look at the “main setup” of the Dallas 1 wire reader program there is an error “failed to create key 1 wire reader” The message is continuously posted. The reader is used in conjunction with the fluke/lr4 snow laser depth system.
I am using Dallas 1 wire reader ver 5.7
WD build 81
I decided to update to build 306 to see if that would take care of a few issues I am having. One other thing that was happening was the 1wire reader program was not opening when I restarted WD. To open the program I would have to go to control panel, 1 wire reader then (without checking anything), close it. The 1 wire reader would open then. It would not close when I exited WD either.
I will wait till a few minutes before the hour to reset the laser sensor timer and then restart WD.
I have not had other reports about those particular problems with the 1 wire reader before so its odd you have had those problems with the latest version
