Beginning with the version 10.37 build 294 and continuing with the current version 10.37 build 305 there has been some miscalculation regarding Solar Sensor using Davis VP2 solar sensor.
The “Current % reading” is always showing 0%, no matter what the current raw reading or Maximum (calculated) radiation for Lat/date is showing. For example see the screen shot below that shows "Current raw reading of 56.0 w/m2 and Maximum radiation value of 202. It should calculate 56/202 = 27%, yet it shows 0%.
The “Maximum radiation for Lat/date” (calculated from Long/Latitude settings) is inconsistent and varies widely in unbelievable values. The second attached screen shot shows this with a “Maximum radiation for Lat/date” = 4, taken just a few minutes after the first screen shot. This was captured at 10:05AM local time when it should be calculating a value > 200.
David
http://www.coupevilleweather.com/
