I have been looking through all the posts regarding the cloud base script and still cannot work out why I cannot get it to work. I get http://www.wanakaweather.co.nz/weather1/cloud-base.php cannot be displayed because it contains errors. When I test it with ?html=1 added I get:
with no graphic. The time is wrong as well as the zone. I was hoping to add the graphic as well as a gauge reflecting cloud base if I can. Any ideas? Attached is the script as I have used it.
I had changed the TZ on line 154 even though no Heavy Weather (should know by now that there is always a simple solution when you know where to look). The images were not loaded art all so no wonder no display. I have gone and sorted that and a great result. Now I just have to figure out how to actually use that result. Thanks for reply.
Sorry I removed that bit as I realised that I did not actually have the images required anywhere. I downloaded them and placed them as images in mt weather1. The testing displays a graphic I just do not know how to get it actually on the site.
Thanks for your help. I need to put the code into ajax-dashboard.php but I am unsure exactly where. All my attempts so far result in errors. I am sure it is simple but this whole php thing is difficult to get your head around.
