I modified the wxall.lastret.php to adapt to changing HH:MM, I hope HENKKA agrees with this messing with his scripts.
- Unzip the attachement
- Locate the current wxall.lastret.php, inside wxsim or a subfolder and make a backup-copy of that script.
- replace with the unzipped version from the attachment
As there are multiple versions of this script, you could be using a different version.
So if there are new and strange errors, replace the script with the backup you made in step 2.
I tested it with your “2015-10-10_07:12_UTC” lastret.txt and it worked OK.
wxall.lastret.php.zip (9.81 KB)
