Hi.
I have noticed that the Send 10 min avg direction on the Wunderground setup window isn’t working. When I activate it, nothing changes in WU, and when I open the window again, the option is unticked as if I had never enabled it.
Also, I cannot seem to be able to import data with the Cumulus import tool. I select the file and the date, but once I press import, nothing happens. I checked the program error log and this shows:
ERROR: ‘23-09-11;13’ is not a valid integer value System.SysUtils at time/date 23:33:7:113 27/08/2015
The date format on my computer is exactly the same as the one in the log files, and I have used this tool before so I don’t know what could be happening. I seem to remember there was an option to change the date format and the separator format but they are no longer there.
