The updates goes so fast that I have problems to update.
Question:
What can the reason be that my weatherstation dont update?
Haven
Question:
Haven
Yeah well… its hard when you get suggestions not to add them when you can. At least Im trying to make the updates more and more easier to perform You should have seen how this all worked year ago Settings files overwritten with each update, changes necessary directly in code… no cPanel…
I would be maybe looking for a new host? as do experience what you are talking about with your page..it did load..but was slow..then a link from the menu will not work and now the page will not load for at all
strange... your homepage loaded very quickly, but everything else times out. Would be useful to see the error log which would show why it failed. It didnt load even the admin login page, which has no external data loaded so it is not because of some external lagging source
I will be contacting the host (easily.co.uk a branch of virgin) to see if they have made some change and if they can sort it out, with a threat to move my site elswhere. I did check how much space I was using and its less than 10% of my allowance so that shouldn’t be an issue
How to I find the error log?
Phil
Look for “logs” folder above your server root, same level as “public_html” or “www”. But not all providers show it, eg. mine does not. This again is something your provider will know and they can even check the error log themselves. This is where all problems are saved, which script, which line, what caused it
[color=red][b]Plugin Update
[color=red][b]Block Update
re the RR issue from the WD API
if you are set to use the Davis Rain rate in WD and or Davis Rain total (i.e provided from the console)
then make sure to being the latest .zip update of WD
[color=red][b]New Plugin
Hi.
Regarding the webcam plugin, it say
Meteotemplate 13.0 Lemon
Hi guys,
as mentioned in a previous post, this is a very minor update, I only needed to add some things to the index file, which will greatly increase potential for new blocks / block improvements. I have also fixed one minor bug in one of the pages.
I am primarily now working on version 14, which should be ready probably in a few weeks. I started working on version 12 in December, and I only wanted this to be about the api, which was problematic and required co-ordination and synchronization with other developers. I have started working on version 14 in January after your suggestions from the questionnaire. However I decided to release this one extra update with just the very few files because of the potential it will bring.
[b]The update should take you maybe 10 seconds
[quote author=tobydude link=topic=60996.msg520865#msg520865 date=1490260372]
Hi.
Ok. My photos are not saved to the same server that Meteotemlape is on.
The webcam block works fine. Here: [url=http://fj
then this could be the issue because in the block, the image is loaded by the browser, in the plugin, it is loaded by the server and if your server has some configuration that does not allow loading external sources like this, then this is a problem.
Ok. Thank you.
Hi guys,
just like there is lots of blocks there is also lots of languages now, so again to make it easier and better adapted to the current situation, I [b]added a new link in the Translations section
Hi guys,
[color=red][b]New Block
[quote author=Jachym link=topic=60996.msg520912#msg520912 date=1490364239]
