Hi Carl,
no, you can of course import whatever you like. The way these scripts work is that you can add any logs and after each import, the database again sorts by date, moving your most recent import “in front of” the previous if the dates are before it. So if your 2015 logs worked then I would assume there should be absolutely no problems with 2014.
