is that a new issue (the data stopping) or?
The data dropping isn’t a new issue. It has happened twice in the 5 days I have used this weather station. I’m not sure if it’s weather display related or not as I have not used the Oregon Scientific supplied software yet.
maybe check to make sure windows is not powering down the usb port? (selective suspend)
I thought I had disabled selective suspend but I was wrong. I have now done so and will monitor. Thanks Brian.
Another anomaly. The rain reading on the WMR-89 console shows 1mm, on WD it shows 0.1mm. Same when the level on the console showed 2mm WD shows 0.2mm. I have done a search but I can’t see where I can adjust this.
ah
I might then have the rain out but a factor 10?
what is the resolution of the rain guage?
i.e how much does the rain increase for each tip?
I’m not sure about that Brian, nothing is mentioned in the user manual. Looking at the datalogger spreadsheet it appears to be 1.02mm per tip but I am not totally convinced about my reasoning.
use a new .zip update of WD re the rain being *10 too low
Thank you, I’ll do that. The location of the rain gauge makes it difficult to operate manually so I will have to observe the next time we have rain. (Shouldn’t be too long here)
Any updates on this question? Thanks in advance.
problem is there is only bits and pieces of information on how this works available
I will give it a try and see if I can get some history data and see i I can make sense of it, over the coming days
OK , I have made a crack at it, and are making progress
it looks like the data is only stored at hourly intervals for the history data?
Hi Brian
We have had a little rain this morning. The console has just changed to 1mm whereas WD shows 0.4mm. From doing a little research it appears that the WMR-89 uses the same rain collector as the WMR-180. I don’t know if this helps or not
are you sure you are using the latest update (.zip update)?
I thought I was up to date from when you last asked me to download the zip file but as a diagnostic I have downloaded the file with the description:
“Display ,.zip update v 10.37S Build 67
for Windows XP (with updates),VISTA/W7/8/8.1/10 (unzip to where WD is installed and note the new .exe name, WeatherDisplay.exe)
Version on 26 February 2018 - 00:57:54”
I will keep you informed
i have managed to a test here and you are right, WD is only increasing by 0.4mm
I will investigate…it might be that the station is sending inches instead of mm or similar
OK, I have found out that the station is sending inches of rain (but when all other data is metric)
I will upload a fix and let you know
