The screen in the control panel only allows you to select one of the OS weather stations and I set this to WMR100.
There are no errors, and the debug screen says everything is ok - however no data is displayed on the main window.
Oh and it’s definitely USB, and not Wifi. The device appears in my Windows7 “Devices and Printers”. The software it came with is nice enough, just doesn’t have a way to automagically log to a file. It has to be done as a manual export and can’t be scheduled. Hardly a “pro” weather station.
what shows in the separate running wmr100.exe program?
(that should be running in the system try…click on that icon)
All measurements come up, but just with default or 0 values.
I will try to attach a screenshot…
I am a software dev by trade so happy to provide lower level info as requested.
what shows in the separate running wmr100.exe program? (that should be running in the system try...click on that icon)
thats the info I am looking for
Let me know if there is anything you need.
but I have posted what the info I am looking for
I am looking for what shows in the separate running wmr100.exe program (click on that icon running in the system tray)
Oh sorry, I thought you meant something else.
The tool tip on the system tray icon says WMR300, whereas the executable in windows task manager shows as WMR100.exe
This snip shows the window I think you are after as well as the executable name in the background.
looks you have selected a wmr300 instead of a wmr100
select the wmr100 in WD
then restart WD (the running wmr300 program should close when close WD and then the correct wmr100 program should start up)
I have tried to set it to WMR100 many times now. I always hit the close/save button. I try exit and start as admin, or start as normal. I have tried restarting.
When the app starts, it fires up WMR100.exe in the background. This then periodically fires up the wmr300histolder.exe, but never for long.
It seems stuck. Maybe I should un-install and reinstall???
yes
try starting over
delete the windows registry settings (see under action in WD)
exit WD
then delete the wdisplay.ini file
then start up
Scratch that. I un-installed. Deleted the registry keys and OS folders, restarted and re-installed.
It not appears to have the correct data gatherer in the system tray but as you see from this screenshot, it’s not updating the main display. The number in the data gatherer just keeps cycling.
does the weather station USB device show up in device manager, ports?
It does show up and the very basic software that it comes with talks nicely to it. I always close and kill that executable just in case there is a conflict.
I downloaded Cumulus and tried that. It offers a WMR88/WMR100 setting also and that won’t display anything. My preference is Weather Display.
interestingly it shows up as a com port 3
instead of a HID USB
so that is different to the WMR100
so thats one problem right there
Hi - I have exactly the same problem , I have chosen just WMR100 and have checked that WMR100 is also running in the system tray. I have checked I have got the correct port selected (COM4) in WD But no data is being received by WD?
I also have the OS software working (as mentioned by the OP) …is there a fix for this or something I am missing?
one way would be to find out how the data is communicated via the software that comes with it, via the com port, via a com port spy program
I gave up on this and grabbed their LW301 product. It meant I could use the existing sensors from the WMR-89 which was cool and I just wrote my own software to read and store the data, which is what most of us want at the end of the day.
I have total control over the data and can post off to webservers like Weather Underground who provide a pretty good free service.
I’ve just brought one of these, did anyone get it working with WS?
As its on comport 3 will setting it as the WMR 928/968 work?
