I’ve not used 1 wire HobbyBoards before so need some help setting it up to work with Weather Display, I have a USB adapter (DS9490R-P) plugged into a 8 Channel I/O board (8CIO8-R1-A), the OneWireViewer has picked this up and shows the Name: DS2408 and a long device address, going into the ‘Switch’ tab on the viewer, I can toggle the relays on and off, so that bits seems ok.
In Weather Display (Ver 10.37R265) I selected Control Panel >>Dallas 1 Wire>>12 Volt Switch, clicking on ‘Search for switches’ brings nothing up and I’m not sure how to get WD to recognize the 8 channel I/O board and then how it would ne configured to operate an on board relay when a wind threshold has been reached, so I’m a bit stuck!
Any help would be appreciated.
Cheers
Ian
