Author Topic: Weather Display won't authorize with Twitter (Resolved 3 yrs later!)  (Read 3242 times)
Offline Varadero
  • Huntingfield Suffolk
  • Win 7/Srvr 2008R2
  • Firefox 37.0
    • Huntingfield Queens Oak
Re: Weather Display won't authorize with Twitter
« Reply #15 on: May 07, 2015, 03:08:49 PM »
Hi Brian
Have collected the file for your interpretation. Must be the same for the new Twitter account I set up too.
I'm away about 15:00 GMT Friday
Regards
Richard
Offline Varadero
  • Win 7/Srvr 2008R2
  • Firefox 37.0
« Reply #16 on: May 07, 2015, 04:40:54 PM »
Hi Brian
Reading online about Twitter authentication issues, I have subsequently cleared autocomplete caches in IE11 and Firefox hoping that might resolve the issue in view of the results in the debugging log, but it still hasn't made any difference. It looks as though this is where the issues lay, but I have used the Twitter ID exactly as it appears in the account and with the appropriate password. I'm flumoxed!  :roll:
Richard
  • Davis VP2
  • New Zealand
  • Win NT 6.3
  • Chrome 42.0.2311.135
    • Weather Display
« Reply #17 on: May 07, 2015, 06:46:52 PM »
the ID and password in the twitter setup in WD is not important
what is important is entering the correct ID and password in the authoristion window that shows up
this error
 Could not authenticate you
to me means you are not entering the correct ID and password in that window maybe?
I will do a test here of a new twitter account setup
Offline Varadero
  • Win 7/Srvr 2008R2
  • Firefox 37.0
« Reply #18 on: May 08, 2015, 06:51:15 AM »
Hi Brian
There is some confusion between Twitter ID and Twitter Username. For Twitter Registration I've used RichardTyler11. If you look up that registration, on Twitter, you're given a long number which is called Twitter ID.  I've tried that as well all to no avail. I even created a new Twitter account and the same happened with that.. just won't authorise. I've changed my password back to the original and still nothing. I can't make head nor tail of it.
Regards
Richard
Bashy
  • Guest
« Reply #19 on: May 08, 2015, 07:30:12 AM »
Have you let anyone else try with your account? perhaps thats the next step....
  • Davis VP2
  • New Zealand
  • Win NT 6.3
    • Weather Display
« Reply #20 on: May 09, 2015, 02:15:02 AM »
you should be using the login details you use to log into twitter.com (username/password)
in the authorise window from the WD setup
I will do a test on a new twitter account sign up
  • Davis VP2
  • New Zealand
  • Win NT 6.3
    • Weather Display
« Reply #21 on: May 09, 2015, 02:36:39 AM »
tested and works here with a new twitter account I setup
(meinwindy3)
https://twitter.com/mewindy3
Offline Varadero
  • Win NT 10.0
  • Firefox 61.0
Re: Weather Display won't authorize with Twitter (Resolved 3 yrs later!)
« Reply #22 on: August 09, 2018, 10:20:07 AM »
Hi Brian and et al. I was not able to resolve this issue until a few days ago when I did a reinstall of Windows 10 because of a major networking issue and the problem resolved itself with a simple log back into Twitter. Something must have screwed up way back when and the reinstall of WD and W.10 fixed it! Hey ho I'm now 3 years older but none the wiser!
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 67.0.3396.99
    • Weather Display
« Reply #23 on: August 09, 2018, 06:17:21 PM »
the deleting of the twitter.ini probably was the trick
Offline Eagleizer
  • Maryborough, Queensland. OZ
  • Win NT 10.0
  • Firefox 63.0
    • Maryborough Qld.
« Reply #24 on: September 04, 2018, 03:58:14 AM »
It seems that Facebook has again update its API for retweeting, and it no longer works.  :(
https://help.twitter.com/en/managing-your-account/help-with-twitter-for-facebook
The green box at the top explains it.
Offline BWX
  • Win NT 10.0
  • Chrome 68.0.3440.106
« Reply #25 on: September 05, 2018, 07:52:29 AM »
Use iftt.com and use the twitter to fb applet, works 100%
« Last Edit: September 05, 2018, 07:56:05 AM by BWX »
