After the Beta install of WD v.259, Weather Display was sending data to Twitter (and still saying that the last sent was … which looks ok ) but Twitter is not posting the weather tweets (which it has done successfully and reliably for a long while now). Nothing was changed at my end. I have since checked that the number count of chars has not exceeded 140, sent shorter than 140 chars, changed my Twitter password 3 times (revoked permission for WD Display app in Twitter) and with the the password changes have tried to re authorize the WD app with my Twitter username and password but it gets just so far with the authorisation as it seems to hang at the point where I’m told that I’m being returned to the WD app on my PC. I’ve installed WD v.262 now but it makes no difference. Also at the allotted interval for an update, I get another request to authorise the app on Twitter which I duly do and then it hangs as above. As a matter of interest, Weathercloud is still posting to Twitter, and have just seen a missive from Twitter saying that Twitter is not seeing my username and password from WD
Has anyone any ideas where or what the problem is as I don’t know what else I can do?
Tried that, and the twitter ini file was receated with :-
[tokens]
ACCESS_TOKEN=
AUTH_TOKEN=
ACCESS_TOKEN_SECRET=
AUTH_TOKEN_SECRET=
REFRESH_TOKEN=
EXTRA_DATA=
(1kb size) There were 2 Twitteroauth.txt files which I cleared but they were not recreated (probably as the authorisation didn’t succeed). Those files were probably old files (2011 dates) from previous Twitter / WD authorisations but were saved.
Ah, ok. All tokens blank in the.ini does point to an authorisation issue.
Internet Explorer drivers are used by the Twitter program - cache/history/cookies may need to be cleared in IE.
Apart from that I don’t know what is happening for you right now, sorry - I can say that my twitter is updating ok.
All good suggestions which I do appreciate. Have cleared all of those bits and pieces in both IE and Firefox but sadly to no avail! I’ll wait to see if Brian or others can suggest something I’ve missed… but in the meanwhile, many thanks for your inputs
Update v. 11.0.18 and it’s set to update automatically.
With respect to running WD as administrator, I’ll check that out in a moment and report back to you. I haven’t changed anything here and WD and Twitter have not been a problem.
I stopped WD and then “Run as Admistrator”, tried a test send to Twitter but it still hangs during the authorise process. Brian, to save starting another topic, over the past few days I’ve noticed that when I restart WD, the missed data from the Meteohub is slow to load. I know you fixed this a while back but it’s all slowed down and I think thats over over the last few days it’s occured.
Popup Blocker is not turned on. I’ve also set up a new Twitter account and WD won’t work with that either … same issues. I’m going to check out the Firewall and program permissions in a while to make sure something hasn’t changed and I’ll reboot the meteohub and the router and see what happens.
Checked all that I can think of and fundamentally no changes. I just don’t know. WeatherCloud only posts to Twitter once a day, so for the time being I’ll have to put up with that!
Reading online about Twitter authentication issues, I have subsequently cleared autocomplete caches in IE11 and Firefox hoping that might resolve the issue in view of the results in the debugging log, but it still hasn’t made any difference. It looks as though this is where the issues lay, but I have used the Twitter ID exactly as it appears in the account and with the appropriate password. I’m flumoxed! :roll:
the ID and password in the twitter setup in WD is not important
what is important is entering the correct ID and password in the authoristion window that shows up
this error
Could not authenticate you
to me means you are not entering the correct ID and password in that window maybe?
I will do a test here of a new twitter account setup
There is some confusion between Twitter ID and Twitter Username. For Twitter Registration I’ve used RichardTyler11. If you look up that registration, on Twitter, you’re given a long number which is called Twitter ID. I’ve tried that as well all to no avail. I even created a new Twitter account and the same happened with that… just won’t authorise. I’ve changed my password back to the original and still nothing. I can’t make head nor tail of it.
