Daylight saving wxsimate issue.
Hi Tom,
When I try to run manually the wxsimate after along delay shows me the two messages below. If I close them then the wxsimate run. This doesn
I think I have found the solution.
I have uncheck from the customize the choise “Boot up with USNO time”.
Now run fine.
Tom in which case must be choised this selection?
Nick
Almost nobody really needs the “Boot up with USNO time” checked, because your own computer probably has an accurate clock. Mainly, it makes it easier for me when I’m doing customizations jobs for other time zones. Just keep it unchecked.
Tom
