Hi all.
I am setting up a WD system on a RPi, by using a Lacrosse 3600 station connected by a Prolific Technology, Inc. PL2303 Serial Port USB converter.
The system (3600+USB converter) works when connected to a Windows machine by the Heavyweather package.
When connected to the Rpi, the Com port is recognized as /dev/ttyUSB0.
I changed the relevant settings in config.txt and in open3600.conf.
on launching consoled as root, I get the following:
Weather Display vers WD_console_10.4
If use this program,then please consider sending a PayPal donation to [email protected] (Brian Hamilton)
to help with costs, and support, thanks!
www.weather-display.com
Doing minute routine now
./fetch3600: 1: ./fetch3600: Syntax error: “(” unexpected
An unhandled exception occurred at $000EB5A4 :
EAccessViolation : Access violation
$000EB5A4
I realized that the version found here:
http://open3600.fast-mail.nl/tiki-download_file.php?fileId=34
is a generic “linux” version, and most probably is not able to run on a RPi, and explains the error I get.
UPDATE
It compiled by doing “make” in the source subdir.
The executables give no error, but no output at all.
The minute routine starts in consolewd, but after that nothing.
Maybe something wrong in the USB comport driver.
–Federico from Rome, Italy
