I will look into that Met office report next week when i am back from a short vacation. Wim
Thanks Wim
The updated release 2.31 contains scripts for Canadian users for forecasts and warnings from EC. Also an AQHI script on the startpage is added.
Downloads from www.weerstation-leuven.be
All information, downloads, demo after 2015-04-29: http://leuven-template.eu/index.php
Succes, Wim
A new version of Ken True “Global Mesonet Page” is available.
Discussion: http://www.wxforum.net/index.php?topic=20865.0
For users of the Leuven-Template I adapted the scripts to run nicely inside this template environment including multi-languge support.
Download http://leuven-template.eu/downloads/global_map.zip
Succes, Wim
Thanks Wim. Seems to work well.
One small problem though, cluster marker image is not accessible. There seems to be a location error:
Yes, i saw it when I was testing just now for a Canadian problem.
The upload is refreshed.
Download again or change the sarGlobalV3 to glo, if you can search for them. It is on 3 places.
Succes, Wim
Thanks its great now
The beta version for the Dec 31 release is on line for:[s]
- a demo how the template works with Canada forecasts and warnings
- a demo how the template works with USA forecasts and warnings
[/s]
Whats New:
1. Adaptable startpage. In the current release the startpage (menu choice “current weather”) is adaptable on a few points such as which forecaster, yes or no soil info, and an extra YoWindow gadget.
Release 2.40 offers more and different components that can be selected and put in any order om the startpage.
The menu choice to view current available components is the second one on both demo sites.
2. WiKi. The documentation is no longer included in the download. All current release pdf-documents could already be read on-line. I am nearly finished rewriting everything and putting it in a WiKI: http://wiki.leuven-template.eu/doku.php And yes, it is draft typing. But before the end of December I have everything spell-checked. And as Dutch is my native language please be kind about the English version as long as it is understandable. In future releases the WiKi can be downloaded also. It does not need SQL.
3. Test of support ticketing system.On the demo- and WiKi-sites a pop-up support form is available if things are still unclear. Also the http://leuven-template.eu/?lang=en website is created to improve the response times and gather all support type activities in one place . It also uses a different provider as the one for the demo-sites.
For those who want to start testing the Leuven-Template, the download is “finished”. So better use the 2.4b release if you start from scratch.
In January I will write a conversion doc for current 2.3x users.
Thanks for this!
The Wiki already made me correct an error I had on my Steelseries display.
Current releases Leuven-Template: posted at 2015-April-29
All information (WiKi), downloads, demo-sites, userlist and so on are accessible using the support site at http://leuven-template.eu/
Please do not use any other link you find in this forum. If you find a not-updated link somewhere in the “back to 2014” forum pages please send me a PM and I will adjust those posts.
Thanks go to Chris for bringing most of the forum back to live.
Hi Wim
got the host server updated and has php 5.4 on
have done most of the config now
Template link on main site
I have a folder called backup at the same level as weather2 it has most of the file in that are in the uploadWD folder (using dif ftp in WD to work at present) I tried changing it in ws_settings but got 500 error so I am not sure its possible to point to a different folder but is working with the WD ftp option
Harold
As you are probably aware all posts between jan 1, 2014 and april 28, 2015 on this forum are lost from the forum forever.
So I can not refer to or read old postings you or I did.
If you want to point to an other folder for all uploaded data, you have to change line 168 weather2/wsSettingsWeather.php
from
$SITE['uploadDir'] = 'uploadWD/'; // #####
$SITE['uploadDir'] = '../backup/'; // #####
A test: http://www.hc-iom.co.uk/backup/testtags.php?sce=view shows the files are there and accesible from the outside.
Please change this setting and if there are errors, leave as is and send me an e-mail, pm or post.
A 500 error is so general, I have to see if there is some indication what the problem could be.
In some rare? cases the settings in Apache / PHP are such that you are only allowed to acces files in folders in the same “tree”
So root => weather2 => script
This script can then executing here can only see folders in weather2/ and all folder below weather2/
If this is the case you have to contact your provider to change these Apache/PHP settings as it is quit normal to access all scripts within your own website.
Hi.
Is the template for win or mac?
Hi Wim
thats where I went wrong no “…” before the "/backup/"when I tried, " ‘…/backup/’; " worked thanks
Harold
The template is available for 11 Weatherprograms. WeatherDisplay on PC works OK, not tested yet for Mac. I do not expect much problems but need someone to test. Also works OK on Mac with WeatherCat.
Just checking. (I have pc (win)). Have uploaded the weather2 folder and it looks great.
But I guess I will get lost soon. The program is enourmous.
I uloaded the folder weather2 half an hour ago and the ftp (cute ftp) is still spinning as the program is looking for something.
Can I use the scandinavian letters "
[quote author=tobydude link=topic=59560.msg481292#msg481292 date=1430422886]
Ok. I
