Author Topic: WXSIM3in1  (Read 9580 times)
Online wvdkuil
  • Wim van der Kuil
  • Leuven Belgium CET
  • Mac OS X 10.10.5
  • Chrome 48.0.2564.103
    • My PWS at Leuven Belgium Europe
Re: WXSIM3in1
« Reply #15 on: February 12, 2016, 03:21:55 PM »
Frame works better Wim, thanks for reply.
Only in a frame it does not translate to Dutch.
I like this version because it compares temp data with MeteoConsult.
http://www.weersverwachtingen.eu/clientraw/wd-ajax-ml/wx3in1_42.php
Otherwise, I will send you a ticket to add comparisation MeteoConsult in Leuven template ?
(Thats of course most actual version)
Thanks so far
It will run in dutch if you add a ?lang=nl (or &lang=url) to the url for the iframe.
Offline edje1205
  • edje
  • Amsterdam Holland, the Netherlands
  • Win 7/Srvr 2008R2
  • MS IE 10.0
    • http://www.weersverwachtingen.eu
Re: WXSIM3in1
« Reply #16 on: February 20, 2016, 02:19:09 PM »
Did not work, Wim but thanks anyway.
What I did was adding plaintext-parser-lang-nl.txt to wxsim-wxall map, works !  :)
Now I'm uptodate again
Maybe offtopic:
How can I add this page in homepage of Leuven template ?
http://www.weersverwachtingen.eu/weather2/index.php
it's about the possibility to compare WXsim, Meteoconsult and YR.NO
Ed
Woodenshoes,mills,hightech;but random weather
P4 2,2Ghz-2GB RAM-Win7-Broadb.connect
Online wvdkuil
  • Wim van der Kuil
  • Mac OS X 10.10.5
  • Chrome 48.0.2564.109
Re: WXSIM3in1
« Reply #17 on: February 20, 2016, 02:51:20 PM »
Maybe offtopic:
For new pages with an iframe, same as with the Saratoga template, use the newpage (inside _my_scripts) and adapt the part for the iframe, add to the menu (wsMenuData.xml).  Make sure that the width is set narrow/wide enough in the wxall.settings.php
Offline edje1205
  • edje
  • Win 7/Srvr 2008R2
  • MS IE 10.0
Re: WXSIM3in1
« Reply #18 on: February 21, 2016, 02:53:27 PM »
Quote
Done, thanks !
The width in Saratoga is adapted and fine
The height wsLeuven is adapted as well but whatever I do in your page script (in px or in %) can't change the width of the page  :oops: #-o
http://www.weersverwachtingen.eu/weather2/index.php?p=400&lang=nl#data-area
Ed
Online wvdkuil
  • Wim van der Kuil
  • Mac OS X 10.10.5
Re: WXSIM3in1
« Reply #19 on: February 21, 2016, 03:05:36 PM »
Done, thanks !
In Leuven the width of the pages is set in the settings.
You should
1. either increase the pagewidth in the settings
or
2. decrease the width in the 3in1 settings.
Offline edje1205
  • edje
  • Win 7/Srvr 2008R2
  • MS IE 10.0
Re: WXSIM3in1
« Reply #20 on: February 22, 2016, 12:28:30 PM »
Quote
You should
or
All done thanks
Ed
