Have made some progress (trial and error).
Changed the station type to 34 (universal).
Set the Comport to 1.
Get this now:
If use this program,then please consider sending a PayPal donation to [email protected] (Brian Hamilton)
to help with costs, and support, thanks! www.weather-display.com
Data OK
Current data 15:54:55: Temperature= 13.0 Windspeed =0.0 Gustspeed =0.0 Direction =0 Humidity=0 Barometer=1013.0 Daily Rain=0.0 Rain Rate 0.0mm/min
Data OK
Current data 15:54:56: Temperature= 13.0 Windspeed =0.0 Gustspeed =0.0 Direction =0 Humidity=0 Barometer=1013.0 Daily Rain=0.0 Rain Rate 0.0mm/min
Data OK
Current data 15:54:58: Temperature= 13.0 Windspeed =0.0 Gustspeed =0.0 Direction =0 Humidity=0 Barometer=1013.0 Daily Rain=0.0 Rain Rate 0.0mm/min
Data OK
Current data 15:54:59: Temperature= 13.0 Windspeed =0.0 Gustspeed =0.0 Direction =0 Humidity=0 Barometer=1013.0 Daily Rain=0.0 Rain Rate 0.0mm/min
**** doing minute routines now 15:55:00
**** updating clientraw extra files
**** updating data logs
updating wunderground
Sending WU data now
updating records to ini file
WU data to send https://weatherstation.underground.com/…
Wunderground data send Ok 15:55:02
Data OK
Current data 15:55:04: Temperature= 13.0 Windspeed =0.0 Gustspeed =0.0 Direction =0 Humidity=0 Barometer=1013.0 Daily Rain=0.0 Rain Rate 0.0mm/min
Data OK
Current data 15:55:06: Temperature= 13.0 Windspeed =0.0 Gustspeed =0.0 Direction =0 Humidity=0 Barometer=1013.0 Daily Rain=0.0 Rain Rate 0.0mm/min
Data OK
Current data 15:55:07: Temperature= 13.0 Windspeed =0.0 Gustspeed =0.0 Direction =0 Humidity=0 Barometer=1013.0 Daily Rain=0.0 Rain Rate 0.0mm/min
Data OK
…etc…
THEN THIS:
Current data 15:55:59: Temperature= 13.0 Windspeed =0.0 Gustspeed =0.0 Direction =0 Humidity=0 Barometer=1013.0 Daily Rain=0.0 Rain Rate 0.0mm/min
**** doing minute routines now 15:56:00
Data OK
Current data 15:56:02: Temperature= 13.0 Windspeed =0.0 Gustspeed =0.0 Direction =0 Humidity=0 Barometer=1013.0 Daily Rain=0.0 Rain Rate 0.0mm/min
Data OK
…etc…
My …etc… means same type info following.
A couple of issues are that the Temperature is wrong, and the Wind information and Humidity are not correct (seems to be 0). Barometer is actually 1017.8, so that is wrong, but at least getting somewhere.
I have been running Meteohub software, but had problems with the Micro SD card and file failures.
I like the look of your product better and hence tried to install.
Are there certain Linux commands that you run in your programs to open the USB interface and extract the data?
btw, when I do a lsusb on the RPi, I get the following which indicates it recognises the WMR300.
pi@raspberrypi:~ $ lsusb
Bus 001 Device 006: ID 0fde:ca08 Oregon Scientific
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I am not sure what you mean from that statement. I don’t have a meteobridge. I just run Meteohub on the RPi to get the data.
It only takes the data from the USB connection and can’t interogate the WMR300 to get historial data or anything like that.
Which did you end up going with? I am considering moving on from the PC version to a raspberry Pi. I used to leave the Windows PC on 24x7. I moved to an apartment for about a year and got out of the habit of leaving the PC powered on.
I could highly recommend a RPI3b, mine has been running without a flaw for 2 years now, if i did not had to do a apt-get update or an apt-get upgrade every now and then, it would have been running now for almost 2 years non-stop!
Also there’s a new version out for the Raspberry, the RPI4b, but that’s brandnew and probably overkill if you just want to work with consolewd…
New to this forum and consoleWD. I am using a RPi 3 Model B. I have the Raspian Buster with Desktop image on the SD card. Using the Meteo-Pi for the logger with the Davis Vantage Pro2.
I tried to foloow the RaspberryPi consoleWD step-by-step post. I tried to follow the steps without any success.
No disrespect to WVDKUIL for posting the step-by-step instructions.
I have a fair grasp of Linux, not great, but fair.
First step install extra libs
1.1 install usb libs
1.1.1 modify /etc/apt/sources.list
Add one line to that file, remember to use sudo or use the gui in a root file-manager window
have you tried first simply copying the library files in the deploy folder for consolewd to
/usr/lib/ and /usr/local/lib/
(as sudo via command line)
then run consolewd ?
sudo ./consolewd
